| S |
1 |
5 |
| 7 |
8 |
12 |
| 14 |
15 |
19 |
| 21 |
22 |
26 |
| 28 |
29 |
30 |
03-24-2004, 09:11 PM
NV
Cobra Make, Engine: BDR / 347 stroker
Replacement springs
Boudy,
I'm going to replace my springs, front and rear but have some questions.
1. What model BMW springs do I look for? 318, 325, 328?
2. Which engine do I specify?
3. Are the stock BDR springs for a stock ride height BMW or are they lowering springs?
4. Are the stock (newer BDR's) springs a standard replacement BMW spring rate or are they custom made for BDR?
I can't deal with my rear suspension bottoming out any more. Going to have to do something. The ride quality is currently terrible over anything but the smoothest roads. Summer is about here and I want to be ready.
Thanks,
Chuck
"It just goes to show ya, no matter where your at, there ya are"
03-30-2004, 06:18 PM
Cobra Make, Engine: BDR 302 AFR 165
hey Chuck,
Let me know what you find out. I don't know any of those answers either.
03-30-2004, 09:08 PM
NV
Dennis,
Will do. Haven't heard anything yet.
Chuck
03-31-2004, 07:17 PM
NY
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
Chuck
Me too, may have the same problem.
Thanks
Trueoo7
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
04-01-2004, 01:54 AM
CA
Interesting to note. In previous conversations with RD while looking at these cars for some potential friends/customers, this is something that I brought up as a possible concern. i.e. how effective is the suspension, is it adjustable, and can it handle 400 or+ horsepower? The response I got was to upgrade to the M3 suspension at purchase...
I wonder if this is still the recommendation or how it relates as a possible fix to your concern of bottoming out?
It would also be good to know what other performance aftermarket BMW shocks and springs could directly replace what stock shocks/springs you have now. Maybe that is an option as well. Let us know how it goes or what you determine as your upgrade/fix... I'm sort of still watching how the BDR cars shake out over the first couple of years. Thanks.
Good Luck.
Duane
04-01-2004, 03:57 AM
Cobra Make, Engine: BDR 392
rear springs
Ijust test drove my new bdr cobra and it rides great. Why dont you call Reg & FRank at backdraft and have them resolve your spring problem, Im sure they have a fix.
" Ain't never had to much fun"
04-05-2004, 06:26 PM
VA
Cobra Make, Engine: Backdraft #101, 342 stroker
I only have 300 miles on my new BDR #101. So far it handles great, no problems with springs. Has not bottomed out yet, I don't expect it will. (I have the standard suspension). I have gone over some bumpy roads too. It actually handles too nicely for a Cobra. A good friend with a CSX 4000 car said my BDR handles more like his M Roadster than his Shelby Cobra! (go figure). I have the first BDR in the CACC crowd, and everyone that has seen it is very impressed with the quality and appearence of this car. I even had one club member ask.."What's so special about a Superformance to cost $10K more than this?" Nice work Regg!
tfarhood
06-13-2004, 08:05 PM
NY
chuckmynatt
How did this problem ever work out for you? I have 500 miles on mine and the left rear tire is starting to rub on the inner fender well when I hit moderate bumps. Are there any adjustments that you found or coilovers that fit and solve the problem? I have car #38 and I'm getting worried about doing damage to the body if I don't find an answer soon. On the left side I can only get my index finger between the tire and the body. The right side I can get two fingers in between.
Thanks
Trueoo7
06-14-2004, 12:18 AM
CA
Adjustability?
I wonder if some of you that have experienced "rubbing" are running slightly oversized tires as compared to others that are not rubbing?
Are all of you running the type same springs and shocks, and are the shocks adjustable?
...just wondering if there is an apples to apples comparison here between the BDR cars...
If not, I've found that rear adjustable shocks are fairly necessary on Cobras, especially well-powered Cobras that squat really hard under power coming out of turns or under hard acceleration. Adjustability here makes it nice so you can set the suspension based on your (preference) need and condition..... soft for those cruising days, or firm for those more agressive roads or events. I run a different car, but this principle is the same.
Duane
06-14-2004, 07:53 AM
TX
Cobra Make, Engine: BDR #42, 425HP 347 - NASA TX, CMC #55 Mustang Road Racer - Legends 37' Chevy Coupe #43 Oval Racer - Honda CRF450R(I'm afraid to race it), 95' Black Lighting Daily Scooter
The rear suspension has a ride height adjustment. If that didn't get your desired results, second move would be to replace the shocks with adjustable coilovers. This works well as the origional ride issue was solved by only adding 30lb to the spring rate of each side. It's inexpensive, simple, and offers adjustablity.
Now, if you want to completely change springs for racing or whatever reason, they are not BMW replacements. They are BMW springs, but have to be purchased by spring rates, not year-make-model. There are many BMW race parts dealers who sell them. Contact Reg for spring rates and application.
Hope this helps.
Boudy
06-14-2004, 07:46 PM
Cobra Make, Engine: BDR, 351W
Who has changed springs?
I have BDR #88 and there is no adjustments left in any spring. I understand from talking to Reg that the springs were changed somewhere between 85 and 90. I am intrested to know if anyone is having the same problems as I am and what is your car build #.
06-14-2004, 10:06 PM
AZ
Cobra Make, Engine: Beck Lister-Corvette
"chuckmynatt" got another set of springs for his Backdraft from Anthem and they did the trick. I expect that he will respond to this thread soon but if not I will ping him later this week.
Racing in a straight line is motorized bowling.
Taking corners (on a track) is a real sport.
06-30-2005, 06:43 PM
Oh
Cobra Make, Engine: Backdraft #20 302 T5
Sorry to tag on to an old thread, but has anyone added coilovers to the rear? If so, what brand, model etc. Did they help the bottoming? This would seem to be an easier fix than replacing the springs.
John
06-30-2005, 06:57 PM
oh
Cobra Make, Engine: FFR 302 with 373's
I do not know if this will help. I had rear springs on my first Factory Five and did experience some bottoming out , so when I built my second FF I made sure I put rear coilovers on, and it did help with bottoming out and also with the handling and ride. The company that I used was VPM. I hope this helps , but if not just ignore.
07-01-2005, 08:05 AM
CA
Cobra Make, Engine: Cobra-less
I've got #128. I was complaining about the stiff ride and Tony said they went to a stiffer spring because everybody was complaining about the ride.
I adjusted my ride height so there is about 1 inch between the top of the tire and the wheel well opening. I was running 30+ pounds in the tires and was taking a beating (great for the track but not-so-great on the street. Recent threads suggested lowereing the tire pressure to 25-28 pounds and it made a big difference in the ride. I am not sure you will get $3,000.00 worth of ride improvement with the M3 upgrade. Probably just stop faster.
I'm not wild about the stiffness but I am sure it is better that soggy. Duane, you are welcome to take mine out at meeting next weekend.
Cobras Gone But Not Forgotten
