Like Tree9Likes
  #61 (permalink)
Old 07-03-2018, 04:12 PM
tamanaco's Avatar
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
yep...old thread...butt, looks like it still an issue. I had the same issue...them cheap azz hydraulic/electric these switches failed on Fords back in the 60's, and are still failing today. Way to much heat under the hood for them to work for long, IMHO. changed mine to a mechanically operated switch of the brake pedal 10 years ago...and never had another problem.
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
  #62 (permalink)
Old 07-04-2018, 10:12 PM
LMH's Avatar
LMH LMH is offline
The problem I've run into on a couple cars is the use of higher pressure switches that need 60-120 pounds of pressure. Cobras are light cars and don't usually require that much pressure. There are low pressure switches made that engage at around 20-25 psi and work much better in cars like this. Ron Francis sells one but there are other places that sell them as well. Just check the pressure range of the switch before buying.
SGwick likes this.
Alba gu brąth
  #63 (permalink)
Old 07-05-2018, 06:00 AM
Had the same issue. The Ron Francis switch works very well on my car.
  #64 (permalink)
Old 11-24-2019, 03:42 PM
Cobra Make, Engine: BDR #656 402 SR TW
Should I swap pressure switch if it is activating my lower lights on brighter intensity but nothing on my upper lights?
  #65 (permalink)
Old 11-24-2019, 07:09 PM
Your upper lights should be your turn signal lights and are not affected by brakes or running lights.
  #66 (permalink)
Old 11-27-2019, 05:45 AM
Cobra Make, Engine: BDR, 418
Default Brake lights out...
Originally Posted by Red Era View Post
I had the same problem on my ERA. It has a switch that works off of the brake fluid pressure ( located on the master cylinders). Replaced the switch and everything was fine.
Good luck
Exactly .... I was in a "safety inspection" at the Mid-America Nationals and my brakes took a puke.... replaced the switch located under the master cylinder and that was the issue ... there's so much heat coming from the headers, things tend to not last as long under the hood.
  #67 (permalink)
Old 11-29-2019, 05:37 PM
Default Brake switch
That just made my day!! Ingenious!!
  #68 (permalink)
Old 11-29-2019, 10:39 PM
Gaz64's Avatar
This is the way to go.
Can be set at any point you wish to trigger the lights, unlike a pressure switch.
Gary
  #69 (permalink)
Old 12-03-2019, 06:40 PM
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
Came across my old thread (haven't been on in over a year) and glad to see its still helping some owners. I can say that the fix I did over 15 years ago is still working just as good as the day I put it in. (just checked it)
SWITCH and come on over to the other side... its worth it.
Never did post pictures though, still can if someone needs em. Don't know if the pedal setup is still the same since mine is an older car.
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
Rate This Thread:
