Old 09-07-2004, 09:18 AM
Cobra Make, Engine: Backdraft #101, 342 stroker
Default Help - Slave Cylinder info
I need a little help with info about the slave cylinder. My threaded rod between the slave cylinder and cluth fork got a little out of adjustment and allowed the piston in the slave cylinder to pop out while shifting from 1st to 2nd. Thank goodness I was only 3 blocks from home. Here is my question; Does anyone have a part number for the slave cylinder or know if a new piston seal is readily available from NAPA or a car dealer? Reg is not available to ask due to the hurricane and I need an answer fast. I am scheduled to have the car dyno'd this Saturday, so I need a repair quickly. Any info on seals or entire slave cylinder would be appreciated.
Thanks.
tfarhood
Old 09-07-2004, 03:47 PM
Smile
For those of you that have the newer cars (mine is #101), the slave cylinder is that of a 1988 Mazda B2200. The dealer couldn't help me with the slave or the seals, but the local auto parts store had the exact slave for $15. Why fix it if you can replace it for that amount. The dealer wanted $60 and didn't even have it. It pays to check around. Thanks to Frank Dodd for the info, and for answering the phone in Florida while recovering from the hurricane.
tfarhood
Old 09-07-2004, 05:41 PM
Cobra Make, Engine: BDR 302 AFR 165
Good info to know. I've logged it in case I need one in the future.
Thankks
Old 09-08-2004, 04:36 PM
Anthem Motors in Phoenix sells a Wildwood slave cylinder with bracket, line and fittings that is much better than factory. Look them up at www. anthemmotors.com. Tell Jon I said Hi.
Old 09-08-2004, 04:59 PM
Cobra Make, Engine: Cobra-less
Anthems Wilwood package is really neat and works well. If you have the short clutch arm and choose the outer hole on their mount, it is a perfect setup(a pull not a push). Their bracket set is machined aluminum and bolts through the motor mount. Caution, make sure you get all the necessary fittings. I was missing the adapter fitting for the hose to slave connection and could not find locally (wrong type flare). I had a custom hose made.
P.S. the slave is available from Summit.
Cobras Gone But Not Forgotten
