Old 01-19-2005, 06:29 PM
got snake?'s Avatar
Cobra Make, Engine: 396 long block, PROBE Forged Dished pistons 8.75 to 1 and Vic Jr. heads from Engine Factory. Tremec TKO. BDR#244 Sterling Gray/Silver stripes. 17in polished wheels, glove box and tonneau cover.
Default BDR-351w with RPM air gap...
Will it fit? Well I guess I should ask if the Vic Jr intake will fit. If that does then the air gap shouldn't be a problem. Any input?
sid
T.S.B. of The West Side Cobra Club
N.D.N.P.N.P.
Old 01-19-2005, 06:46 PM
Cobra Make, Engine: BDR 302 AFR 165
I have an RPM air gap on my 302 BDR and I run a drop based 3inch by 14 KNN. I've seen several 351 cars with vic jrs. I don't think it will be a problem. I think the 302 is 1 inch lower so you may have to run a 2 inch by 14 air cleaner.
later dennis
Old 01-19-2005, 06:50 PM
Cobra Make, Engine: BDR Roadster ,427 R
Hi there,
With a 351w engine you can still run a Super Vic intake. You need to use a dropped base air cleaner to clear the hood. The standard FMS Oval Cobra air cleaner will also fit but the clearance is tight.
Reg
Old 02-24-2005, 01:46 PM
Secret Squirrel's Avatar
Cobra Make, Engine: Backdraft Racing BDR144
Sid,
I have an Edelbrock Airgap intake on my 351w with a drop base air cleaner and it clears the hood just fine.
Wayne W.
Pewter with Steel Gray Stripes
Old 02-24-2005, 04:20 PM
got snake?'s Avatar
Do you think the Edelbrock Pro Flo air cleaner will work? Cause thats what i got.
Sid
N.D.N.P.N.P.
Old 02-24-2005, 05:16 PM
Cobra Make, Engine: Classic Roadsters, Tweaked 351W, T-5Z, CRII Tech Support Team.
Getting air cleaner clearance on any 351W Cobra is a challenge. And, smaller air cleaners, even the Edelbrock oval, cost HP as I learned during dyno testing.
Best compromise was K&N 11" which filters through sides and top. And, as I learned, the filter element on the Edelbrock oval (a K&N), is also an 11", and fits the K&N 11" top, and is slightly taller.
