December 2025
Old 03-27-2005, 06:43 PM
Cobra Make, Engine: BDR, 351/408 stroker - TKO 600
Default Brake light switch
To all BDR owners you may find an issue with the mechanical brake switch. Reg is reporting problems and I have experienced the issue myself. Now to find the best solution.? Reg is recommending a hycraulic type switch but that to has been problematic due to the heat from the headers. I am working through using a plunger type switch found at ron francis wiring for about 9.95 a simple but problem free? solution. Would need to add a bracket to hold the switch in place and drill or weld a stub to the brake pedal to have the switch rest against.
Anybody have a gfood solution?
Old 03-27-2005, 09:01 PM
Cobra Make, Engine: Backdraft, 302, Tremec 3550. #038
The hardest part is finding something underneath there to attach to, theres nothing. I made up a bracket and attached it to the throttle bracket plate. It works but I don't know how long it will last also tight spot to get into and fabricate something.
The good part is if you can figure something out, the wires just pull off the pressure switch, you feed them back through the firewall and plug them into the mechanical switch and the lights work just fine with no modifications.
Kids in the backseats cause accidents, accidents in the backseat causes kids ! Good reason to get a Cobra !!!
Old 03-28-2005, 05:56 AM
Cobra Make, Engine: SPF 2682, Roush 427
I used a motorcycle pull type switch attached to the clevis pin in the brake pedal, mounted on the cross bar next to where the steering column mounts. It seems to work well. My only concern is the current rating on the switch.
Chet
Old 03-28-2005, 06:26 AM
trularin's Avatar
Member of the north
Cobra Make, Engine: A Cobra
Tried the motor cycle thingy, couldn't get a clean spot to attach it.
I ended up with the pressure activated, inline switch. Closes when there is pressure in the brake line.
This will work on just about any car. If you want to do this, make sure you get the line Tee to connect the switch to the line.
They can be purchased from Pegasus Racing. WWW.pegasusracing.com
Hope this helps.
Old 03-28-2005, 11:29 AM
zipzip's Avatar
Cobra Make, Engine: Midstates work in progress, personally built 302
I love sailing and all, but I think you were referring to www. pegasusautoracing.com
Most of the wiring or gage places also sell them. Here's a link to a search on summit. click here
You might be a redneck if you think the National Anthem ends with "...Gentlemen, start your engines."
Old 03-28-2005, 11:47 AM
I was tempted to try a low pressure switch, but could not decide what thread size to use. Maybe someone here knows.
Old 03-29-2005, 10:37 PM
Cashburn's Avatar
Backdraft Racing Dealer
I stand corrected, they are going to use a new pressure switch.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 03-30-2005, 05:59 AM
trularin's Avatar
Member of the north
Opps, my bad, wrong site. Sorry.
Old 04-08-2005, 10:31 PM
Well ended up fabricating a bracket. Drilled and taped the support under the dash. Bolted the bracket with the switch right in front of the brake lever. Voolo the problem goes away. PUURRRRFFFFect!...
