Like Tree3Likes
Old 06-15-2005, 07:58 AM
Secret Squirrel's Avatar
Cobra Make, Engine: Backdraft Racing BDR144
Jeffko,
I also had a leak from the clutch master cylinder area too. The leak was not massive, but more of a seeping/dripping leak after a short drive. I had to wipe the bottom of the MC a few times and I checked the flair connector and it was tight.
It turned out to be the cap. I noticed that the cap was hard to put on and tighten. I could not tighten it enough with my hand. I now use a small strap wrench to finish getting it snugged down. No leak since. I keep that strap wrench in my tool bag in the trunk, because you wont be able to loosen the cap without it.
Wayne W.
Pewter with Steel Gray Stripes
Old 06-15-2005, 11:29 AM
jeffko's Avatar
Cobra Make, Engine: BDR #177 Carbed Ford Small Block
Ahh, yet another victim of the mc cap. S.S. you make 3 confirmed and I will probably make 4. Reg is sending me a new cap that will hopefully take care of it. In the meantime a guy in our club suggested I rubberband a baggie over the cap. It should still have the breathing room of the bag and I can see if it collects any fluid.
Tis better to burn out than to fade away. So "Lite 'Em Up!"
Old 06-15-2005, 11:34 AM
Blas's Avatar
Cobra Make, Engine: SPF#0760
Probably a guy with a red car.....
Old 06-15-2005, 02:24 PM
flipper35's Avatar
I just replaces the old cap seal with one like they use in off road buggies and truggies. Works like a charm. I hope yours is a simple fix and not a cracked line or something.
Brent Dolphin
Old 06-15-2005, 07:01 PM
Cashburn's Avatar
Backdraft Racing Dealer
You may actually find something in the HELP! aisle at Pep Boys etc... it's the company where everything is packaged in red cards... they sell all kinds of useful fix parts.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Cobra Make, Engine: Cobra-less
Back to the actuator for a minute, if I may, been busy and away from this thread.
Anthem Motors in Phoenix makes a kit with an aluminum block that bolts to the motor mount. And someone else said to just dirll a hole in the side of the motor mount flang on the frame.
Sorry for the interuption
Cobras Gone But Not Forgotten
Old 06-16-2005, 05:49 AM
jeffko's Avatar
Flipper, could you be more specific about what you used and where you got it.
Jeff
Old 08-28-2019, 03:15 PM
Cobra Make, Engine: BDR, 418
Default side vent removal
Originally Posted by tfarhood View Post
Jeffko, these caps on the willwood MC are easy to get on wrong. If you look, the threads on the MC & cap are a joke. I had to try a couple of times to make sure it was going on straight. Also, it may not be down tight, maybe just an eighth of a turn short of closed. It is very hard to see/reach considering its location. When I replaced my MC, I removed the side louver to gain access. It really made it easy to reach. I would not bother to do that to tighten the cap normally, but if you still have a problem, it may be helpful.
I talked with the reps from Iconic Parts (w/ BDR)... he told me the same thing, remove the side vent to access the clutch master cylinder. My BDR has about 4,500 miles and the MC is leaking from the seal inside the cockpit. I ordered a new one from Iconic along with a new matching slave....didn't want to take the time or a chance messing around with the local parts stores trying to match Mazda parts or anything else. Your posts were very helpful and reassuring that I will be able to address the problem.
