Old 07-04-2005, 11:47 AM
got snake?'s Avatar
Cobra Make, Engine: 396 long block, PROBE Forged Dished pistons 8.75 to 1 and Vic Jr. heads from Engine Factory. Tremec TKO. BDR#244 Sterling Gray/Silver stripes. 17in polished wheels, glove box and tonneau cover.
Default Cracked windshield already!
Well the trip to OH I guess got the best of me. Got a crack in the center of the windshield already! And its moving up fast! Any input on how to get it fixed? Should I just call one of those dudes in the trucks to come over and fix it?
REG you got any input? Should I replace it?
Sid
T.S.B. of The West Side Cobra Club
N.D.N.P.N.P.
Old 07-04-2005, 12:11 PM
Rick Parker's Avatar
It cannot be fixed. The guys in the truck can fix "stars & bullseyes" only. Cracks require replacement of the glass.
I have the same thing.
Old 07-04-2005, 01:19 PM
Cobra Make, Engine: BDR #200 with a KCR 575/550 408
I thought when I saw the title of this thread it was going to be something more like THIS.
Sorry to hear about the crack, but huge congrats on getting it done and on the road so quickly!
Old 07-04-2005, 02:16 PM
Cobra Make, Engine: Backdraft #101, 342 stroker
got snake,
If it is a crack from a stone chip, you'll need to buy a new piece of glass. If it is a stress crack cause by installation, Reg should be able to get it replaced. Either way call Reg, it will save you a lot of time by going to the source. Good luck.
tfarhood
Old 07-05-2005, 08:18 PM
Engineer Ed's Avatar
Cobra Make, Engine: Backdraft Racing #223
Last weekend two BDR windshields were cracked while racing at Roebling Road.
Chester Littlefield (BDR # 12) and mine (BDR #223). Jay Baranzano also cracked his windshield a few weeks earlier racing at the same track. This is Chesters 2nd cracked windshield while racing.
Perhaps its the aluminum frame that is allowing for greater flexing and the resulting cracked windshield???
I spoke to Reg about it briefly and he is looking into it.
My suggestion (for the racing crowd) is to replace the glass with Lexan.
I raced my last Cobra (FFR) for 5 years and never cracked a windshield. However the frame was chrome over brass, not aluminum......
Chester and I both have the M3 suspension (I am unaware of the suspension in Jay Baranzanos car). Perhaps the stiffer springs and sway bar causes too much stress on the frame allowing for more flex??
Ed
I was told it doesn't get cold up here.
WTF... I'm freezing!
Old 07-05-2005, 08:27 PM
Cobra Make, Engine: SPF #1310, 392 Stroker, T5
Default Same here SPF#1310
Stone at high speed cracked my windshield also this weekend.
Where do you get replacement windshield for SPF?
Thanks, Jeff.
Jeff Corsello (gotalbots)
Old 07-05-2005, 09:46 PM
pneall's Avatar
Mine also cracked after a track day. After getting a new screen I noticed during refitting that the original installer of the screen had pre loaded the screen by misalignment of the dash mounted centre support bracket. I redrilled holes to ensure no preload and have had not problems since.
Phil
Old 07-06-2005, 02:56 AM
gotalbots...call your SPF dealer. Bill
Old 07-06-2005, 06:37 AM
Specialk's Avatar
Cobra Make, Engine: 427 SC
Send a message via AIM to Specialk Send a message via Skype™ to Specialk
A local glass shop can replace it in no time flat. I've never checked on a new piece of glass, but I think they are <$250. Glass shops usually get $50 to put in the new glass. I have replaced several, and it would be worth it to me to spend the $50 from now on!
kris kincaid
Old 07-06-2005, 07:05 AM
Secret Squirrel's Avatar
Cobra Make, Engine: Backdraft Racing BDR144
Mine cracked also back in February. Not a stone chip. It happened after a short cruise around town. Parked it back in the garage and the crack appeared the next morning. It started from the bottom of the frame on the drivers side and traveled upward and took a 90 degree turn toward the center. I have heard of some other BDR's with the same problem. I am currently waiting for a replacement from Reg.
Wayne W.
Pewter with Steel Gray Stripes
Old 07-06-2005, 07:40 AM
I remeber reading a memeber post where he installed an aftermarket windsheild and frame from finish line to replace the backdraft. Why go back with a BDR frame/glass, it appears they have a design flaw. It is too coincidence with this many windsheilds breaking.
Old 07-06-2005, 07:47 AM
Cobra Make, Engine: B&B Manufacturing,351 SVO stroker from Bennett Racing
If memory serves me correctly I believe SPF cars had a similar type problem a year or so ago. Can't say that those cars have an engineering flaw, probably just got a bad run of glass in the windshields. The important thing is how they address the problem and take care of their customers.
J.A.
Old 07-06-2005, 08:57 AM
I'm on my third windshield in 2 years..... I think the fiberglass body is flexing, and tweaking the hard-mounted windshield. I loosened the mounting bolts, using Nylock nuts, to allow the windshield to move with the body, and so far have not cracked another one in 6 months. I even had a clueless passenger grab the windshield frame to pull himself out of the car, and it didn't break.......his arm did, though!
Old 07-06-2005, 10:37 AM
got snake?'s Avatar
Called Reg and he wants a pic to see if it can be covered under warranty...to be continued...
N.D.N.P.N.P.
Old 07-06-2005, 10:46 AM
WARRANTY !!!!!?????
Old 07-06-2005, 12:11 PM
Mike Braatz's Avatar
INTERESTING --
WHILE AT THE FLING -- FRANK KLINES AND I WERE FLYING OUT INTERSTATE 70, EAST BOUND, WHEN A SEMI KICKED UP A NICE SIZE STONE AND CRACKED THE WINDSHIELD AND IF IT HAD GONE THROUGH IT WOULD HAVE HIT FRANK RIGHT BETWEEN THE EYES, HOWEVER, I'M SURE IT WOULDN'T HAVE HURT ANTHING.
CALL -- DANA AT SHELL VALLEY THEY MAY HAVE A REPLACEMENT --
Old 07-06-2005, 01:15 PM
Just spoke with Dynamic Motor Sports re replacement glass for spf #1310. Possible Several MONTHS wait!! eeek.
Old 07-06-2005, 09:21 PM
uncltodd's Avatar
Cobra Make, Engine: BDR #139, Indigo blue, white stripes, KeithCraft 351W, 315 WHP, 17" Boyd Smoothies, dual roll bars, gunrack, assorted young females
#139's windshield cracked vertically top-to-bottom in two places while sitting in KCMS's shop in Plano, TX waiting for the engine install.
I replaced with an aftermarket which seems happy, so far, but I will have to drill and tap to make the original wind deflectors mount up.
Think I'll leave them off, I'm used to it.
No, I'm not bitter.
Warranty? What warranty?
Show me one.
It's probably attached to my vinyl top, which I paid for and was supposed to be delivered in mid-December, 2004.
No, I'm not bitter.
UT
Eagles soar- but weasels don't get sucked into jet engines.
Old 07-07-2005, 08:49 AM
Cobra Make, Engine: backdraft racing 302 ford
I have #84 with 4000 miles on it , coming back for the hot rod power tour a crack apeared on the drivers side about 2" long and now is down the whole windshield. I live in florida and the insurance co by law will replace the windshield for free.
Ed
Old 07-07-2005, 09:01 AM
Cashburn's Avatar
Backdraft Racing Dealer
No, I'm not bitter.
UT
I think you paid Boudy for that top. Did he deliver it yet or refund your money?
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
