Like Tree25Likes
  #41 (permalink)
Old 01-14-2020, 09:43 AM
I'd contact Brent Lykins. His motors reputation precedes him and and he uses name brand parts and not Taiwan or China knockoffs.
Although this is one of lowest priced motors from his site, it is complete and looks to only need a flywheel, trans, bellhousing to be a true drop-in by you.
He also sells those items. (saves you from doing run-out placement of the bellhousing).
Lykins Motorsports 351W Cobra Special
*Fully machined production 351W block
*ARP main bolts
*Clevite main/rod bearings
*Comp Cams hydraulic roller camshaft
*Scat crankshaft
*Ford Racing timing set
*Ford Racing fuel pump eccentric
*ARP cam retainer bolts
*ARP camshaft bolt
*Scat forged I-beam rods
*Probe forged pistons
*Total Seal rings
*New timing cover
*New timing pointer
*Professional Products harmonic balancer
*ARP balancer bolt
*Stock replacement water pump
*Felpro gasket set
*Edelbrock Performer RPM/RHS cylinder heads
*Ford Racing hydraulic roller lifters
*Comp Cams lifter spider
*Trend pushrods
*Comp Cams rocker arms
*Edelbrock Performer RPM intake
*Melling oil pump/oil pump drive
*ARP oil pump/pickup bolts
*T-sump oil pan/pickup/dipstick
*MSD distributor with polymer gear
*Distributor clamp
*Carter mechanical fuel pump
*Ford Racing valve covers, valve cover breather
*Autolite spark plugs
*MSD plug wires
*PCV valve/hose
*Holley 4bbl carb
*Low profile air cleaner
*March aluminum pulleys and alternator bracket, accessory belt
*Water neck/thermostat
*100A 1-wire alternator
*Stainless steel exterior bolt kit
*Braided stainless steel fuel pump hose with AN fittings
*RAM pilot bearing
*Powermaster gear drive starter
*Rotating assembly balanced
*Fully assembled
*Wix oil filter
*Dyno tested
*Build sheet with all specs
*Build pictures
*Dyno results and dyno video provided!
$8699
  #42 (permalink)
Old 01-15-2020, 09:14 AM
Double check that polymer gear on the distributor. You might want to ask some questions on that.
Also, spring for the best heads you can afford. Maybe port work on those heads, or maybe a better set of heads. The difference in cost may be fairly minor. It's worth a conversation, if you could afford a few hundred more.
Quentin Z likes this.
  #43 (permalink)
Old 08-19-2020, 06:04 PM
Registered User
Cobra Make, Engine: BD 427 Iconic
Still helpful to a newbie like me. I just bought my cobra. 427 Iconic. I've only driven it around the block once so far. Rainy season in FL.
  #44 (permalink)
Old 08-19-2020, 07:53 PM
cycleguy55's Avatar
Composite / polymer gears are widely accepted for ALL camshaft types.
Summit Racing:
  • Made from a super strong polymer.
  • Durable and lightweight.
  • Compatible with all camshafts.
  • More expensive than other types of distributor gears.
https://help.summitracing.com/app/an...hould-i-buy%3F
EngineBuilder:
Composite (offers great life, conforms well to the mating cam gear, and is compatible with ANY camshaft gear material)
https://www.enginebuildermag.com/200...tributor-gear/
Brian
  #45 (permalink)
Old 08-20-2020, 12:40 AM
eschaider's Avatar
The composite gears are softer than their corresponding metallic counterpart, Brian. The composite distributor drive gear needs to drive both the distributor and the oil pump. The distributor takes little to no power to drive, relatively speaking. A stock oil pump that pumps oil at only 50 psi or so takes a lot of power to drive and the composite gear becomes the weak link. A high volume / high pressure aftermarket pump would be death on a composite gear. The best solution is a metallic gear that is compatible with the material the camshaft gear is made from.
The silicon bronze gears while sounding like the best choice will rapidly wear when asked to operate in a non race car sort of environment. Even in a race car environment they need to be regularly maintained because they still wear, producing unwanted changes in the engine's ignition timing map.
Ed
  #46 (permalink)
Old 08-20-2020, 04:37 AM
KDubU's Avatar
Cobra Make, Engine: Factory Five, 351w
I’m not a fan of polymer gears either and I am no gear head. Take it from the experts, still like the package and price from Lykins.
  #47 (permalink)
Old 08-20-2020, 03:58 PM
hauss's Avatar
15 years! and still going I have a 427 stroker man o war block but, that said I would go 408 same hp more reliability from what I have been told. By the way no problems with my motor only the guy behind the wheel. Just keep it ford IMO.
  #48 (permalink)
Old 08-21-2020, 10:46 AM
Cobra Make, Engine: Black CSX 4910, Roush 511 8 stack
You can never go wrong with a Boss 9( this one is going in my 67 mustang
MKS427 and hauss like this.
  #49 (permalink)
Old 08-21-2020, 03:22 PM
MKS427's Avatar
Cobra Make, Engine: FFR MkIV 427
Do you think it would fit in a Cobra, between the foot boxes?
  #50 (permalink)
Old 08-21-2020, 04:12 PM
Yes it could but completely overkill. There have been a few real deal 427 SOHC motors in Cobras. You can easily fit a big block from 427-600 ci if you want but the small block stroked 427 are lighter and make great power( 500-600 hp)
I have also put a modern coyote modular in a superformance and it was faster than stink with “only” 460 hp
MKS427 likes this.
  #51 (permalink)
Old 08-21-2020, 06:52 PM
MKS427's Avatar
I'm running a 351W/427 Dart block. Financially, it's the best bang for the buck.
  #52 (permalink)
Old 02-14-2021, 05:17 AM
Just order a Craft Performance 363 (Dart Block) stroker to replace my 347. Lance says it will easily make 500hp on the dyno. The advantage in my case is it just drops right in, same dimensions and accessories as any 302 based small block, same deck height. Near Big Block power with all the weight and packaging benefits of a 302
IMLost likes this.
  #53 (permalink)
Old 02-14-2021, 09:00 AM
Thor maine's Avatar
GM LS is the best way to go!!!
  #54 (permalink)
Old 02-14-2021, 09:15 AM
hauss's Avatar
Not in a cobra (Ford) ls will hurt resale nothing against the ls its a great motor.
