Like Tree3Likes
Old 02-21-2006, 06:45 PM
Cobra Make, Engine: Backdraft 302
Default hood strut
I have an early car, #31, that has a single gas strut that holds the hood up. It lost it's holding power so I asked TriState motorsport (where I bought the car) to try and find me another but they're having no luck. Anyone know where I can get another one of these things ? He's shipping it back to me, I'll post a pic when I get it back.
-- Ray D
Old 02-21-2006, 07:30 PM
Cashburn's Avatar
Backdraft Racing Dealer
The shock is custom made at the factory. They even were charging it themselves. I would suggest going to the prop rod the cars have employed since #190 or so on... Tri-State should have no trouble getting that for you.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Cobra Make, Engine: 2002 Lone Star Classics LS427, 428 CJ engine stroked to 464, 580hp/590tq at flywheel
http://www.mcmaster.com/ These folks make all kind of struts. Do a search for struts on their site and see if you can match something. Adding them to my trunk is on my list of to dos.
Old 02-23-2006, 12:08 PM
Cobra Make, Engine: sold BDR #123 351w, Tko 17" full polished wheels
newbdr
I have #123 which also came with a gas strut. After a few close calls with the wind at car shows I ordered the new BDR prop rod.It took less than an hour to install and now I dont have to worry about the strut not doing its job.
BDR0572 likes this.
Old 02-25-2006, 04:56 PM
Cobra Make, Engine: 1965 Backdraft #58, 347 Stroker
Send a message via AIM to Cobracraig
David,
Where did you order your prop rod from? I need to go to the prop rod also. Thanks.
Cobracraig
"Drive it Like you Hate it!"
Old 02-25-2006, 05:23 PM
FUNFER2's Avatar
David, I have a lone star cobra but, I'm interested in your type of prop rod also. Can you tell me where to order, the cost, the length and if you would take pictures of it installed showing the bracket mounting, it will be very much appreciated.
Kevin
Kevin
Old 02-25-2006, 06:18 PM
Rick Parker's Avatar
Prop rod, you will need to fabricate pivot mount.
http://www.parts123.com/PartFrame.as...obra_Restorers
Page 1097
Old 02-25-2006, 08:56 PM
55312's Avatar
Ray - McMaster is the easiest way out. They will have your strut and at your doorstep in 2 days. I have struts from them for my hood and trunk. For the hood, I have 30# cylinders on each side. Maybe Katrina could have blown the hood shut but it would have bent a prop rod too. These things are cheap and well made.
Tim
Old 02-26-2006, 05:11 PM
FUNFER2's Avatar
Tim, could you help me out with my posted questions above ?
I would appreciate it.
Kev
Kevin
Old 02-26-2006, 06:46 PM
55312's Avatar
Kevin
My E-M was set up with gas struts but they had long since died when I got the car. The previous owner used curtain rods with little rubber feet! After a long serch, I stumbled on the McMaster site and they had a ton of struts. I measured the old ones and took a wild shot at 50# struts. Overshot that one! It was too much pressure to close the hood and opening it was like a scene out of Monty Pythons "Holy Grail" with the cow catapult. Returned them with zero hassle to McMaster and they sent 30# struts that work excellent. they even sent them on the honor system as I hadn't sent the other ones back yet. For mounting hardware, they have a section in the same area as the struts. For the hood mounts, the originals used something off a Ford hatchback but I couldn't trace the Ford part number. I ended up going to a junk yard and crawling in every Escort hatch back I coould find and got lucky. They were from an early 70's Escort Pony. Took em out and the guy running the place gave them to me for my effort. It was kind of fun cruising the boneyard which had been the source of so many trips for parts in my poor youth. I'll have to get to the shop and measure the length for you tomorrow after work. Too cold right now with the temp hovering around zero.
Stay tuned
Tim
Old 02-26-2006, 08:15 PM
Cashburn's Avatar
Tim,
Lot of effort. The early BDRs had one strut mounted in the center. Sounds like you have duals on your totally different EM. I'm sticking to my prop rod suggestion. Easy retrofit and best overall solution.
BDR0572 likes this.
VINTAGE MOTORSPORTS
Old 02-27-2006, 06:03 PM
Cashburn,
Do you sell the hood prop rod? I have a supercharger intercooler in the way of my center strut and need a new prop rod. I have #58 from Reg. Thanks.
Cobracraig
Old 02-27-2006, 07:40 PM
Doug,
I have been wanting to use the struts on my hood and trunk, but haven't figured out how to mount them. You got any pics?
Bruce
Old 02-27-2006, 07:48 PM
FUNFER2's Avatar
TIM- You're a gas.......LOL ! funny story.
I'll check McMaster out.
Kev
Kevin
Old 02-27-2006, 08:31 PM
Cashburn's Avatar
I can sell you one but it will cost $28,900 plus shipping Reg might have a cheaper solution.
VINTAGE MOTORSPORTS
Old 03-01-2006, 08:27 AM
55312's Avatar
Jay - If you continue to insist on this prop rod thing, I'm going to burn my "Caution Pipes are Hot"stickers in protest!
Tim
Old 03-01-2006, 06:28 PM
Cashburn's Avatar
Then you will have to buy some more! I'm not seeing how I lose here
VINTAGE MOTORSPORTS
Old 05-29-2018, 12:33 PM
Yes I'm rezzing an old thread. After much trail and error I found a suitable replacement for the early BDRs with the gas hood strut. PN: SE115P-20 approx $20 thru Amazon.
Old 05-29-2018, 02:58 PM
Cobra Make, Engine: Backdraft Cobra RT3, Roush 427R Crate Engine, Tremec 6-Speed Transmission
I purchased a prop rod assembly directly from Backdraft in Florida years ago for my Backdraft #101. The prop rod installed easily and the mount on the hood was easy to install. Worked well for me. Iconic Parts-Backdraft has the same prop rod assembly for purchase. (www.iconicparts.com). Check them out.
Old 05-29-2018, 03:03 PM
I had considered the BDR prop rod a couple of years ago but they can disengage with wind gusts. Texas is quite windy. I fabbed a locking rod instead.
BDR0572 likes this.
