Old 03-01-2006, 06:40 PM
mtpockets's Avatar
Cobra Make, Engine: BDR #621, Keith Craft 408
Default Help, my car stalled out today
Here's the scoop. Car stalled out this afternoon in traffic. This is my first time in traffic and it was a bit warm. Engine temp reached 95-100c and would not start back up. Let it sit for 10 minutes, started right up. Ran on the freeway back to the house no problems, car never got above 80c. Got back into town, sat a light for two cycles and died again. Same thing. Let it sit for 10 minutes started right up. Here's the package. 302 with Edlebrock heads and intake, Holley 600, MSD ignition. Pretty straight forward, I need help narrowing it down. Anyone have a similar problem in the past? Fuel, overheating the carb and vapor lock? Electrical, ingnition module expanding and causing the shutdown? Still working some minor bugs out. Thanks in advance for your thoughts.
Old 03-01-2006, 06:59 PM
Cashburn's Avatar
Backdraft Racing Dealer
Where does your fuel line run from the factory line to the carb? Electric pump or mechanical?
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 03-01-2006, 09:27 PM
Dangerous Doug's Avatar
Cobra Make, Engine: ERA 289 FIA #2108
If you have a bad coil, when it heats up the wires will expand and cause a short. When the motor cools, the wires shrink and the coil works again---until it gets too hot.
Grab a multimeter and fire up the beast. Measure the plus and minus sides of your coil. Then, head out for a drive around your neighborhood, and drive it until the engine dies again. Check the plus and minus side of the coil. If it's not reading the same as before, you've got a bad coil and have found the culprit. Wait for it to cool, drive home and change the coil.
The same may be true of the MSD, but I don't know how to troubleshoot that.
Good luck,
Dangerous Doug
Dangerous Doug
"You're kidding, right?"
Old 03-02-2006, 05:16 AM
mtpockets's Avatar
Ok, I have some places to start. I also have an electric fuel pump. Today I leave for Vegas, Monday I start trouble shooting. Thanks to everyone for the help. I'll post when problem is solved.
Old 03-02-2006, 08:46 AM
Dsprint2000's Avatar
Sounds like vapor lock.....
dsprint2000 - rubber down
Old 03-02-2006, 09:52 AM
Cobra Make, Engine: Superformance #1374 with 392 RDI Stroker
Mine did the same thing. Tracked it down the the MSD 6AL box. If you have one installed, this might be your problem. Moved mine from engine compartment to under dash. These things are notorious for not liking heat.
I would check the fuel to rule it out and then get the MSD box checked out.
Mark
Old 03-02-2006, 10:25 AM
wtm442's Avatar
Beam Me Up Scottie
if everything else fails ....
kick it in the asp ....
Warren
Old 03-02-2006, 01:21 PM
SCOBRAC's Avatar
Cobra Make, Engine: -Sold- Contemporary 427S/C # CCX-3152 1966 427 Med Rise Side Oiler, 8v 3.54:1 Salisbury IRS, Koni's.. (Now I'm riding Harleys)
What Dsprint said... Leave the gas cap OFF and try to duplicate the trip you took or replicate the conditions you stalled out in. If you don't stall your tank isn't venting properly and fuel isn't getting to the carb due to a vacuum condition in the tank. drill a hole in the cap which allows air in or get the tank vented to solve the problem.
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
Old 03-02-2006, 01:58 PM
Cashburn's Avatar
Backdrafts have vented tanks.
So the coil and MSD ideas are likely possible too. Where is your MSD mounted? We have a proper aluminum plate we manuf. custom to mount the MSD in a cool, out of the way place.
VINTAGE MOTORSPORTS
Old 03-05-2006, 04:41 PM
BUCKEYE COBRA's Avatar
Cobra Make, Engine: Backdraft #20 302 T5
What's the best way to get your MDS box tested?
My car won't rev pas 5300 , I have an adjustable rev limiter set at 6,200.
Thanks,
John
Old 03-05-2006, 04:47 PM
Cashburn's Avatar
Check the MSD web site, they have a support area that gives a good rundown of checks.
VINTAGE MOTORSPORTS
Old 03-05-2006, 06:03 PM
Blittleton's Avatar
CC Member / Sponsor
mtpockets, check to see what fuel pump you are using, if you are using a holley. CHANGE IT. I have had two holley's crap out on me that very same way. I would drive it and it would shut off, 5 to 10 min. later is would start again. I would look here first. Then check your MSD box.
Bill
Squeaky wheel always gets the grease!!
www.gcperf.com
Old 03-05-2006, 08:08 PM
Rick Parker's Avatar
http://www.msdignition.com/1troubleshoot.htm
Eliminate all variable in the ignition before moving on.
IF YOU DO NOT ALREADY HAVE THEM, GET THE RUBBER ISOLATORS TO KEEP VIBRATION FROM BEING TRANSMITTED TO THE MSD BOX.
Rick
Old 03-05-2006, 08:24 PM
Cashburn's Avatar
As others have suggested look at the MSD. I have seen this in another car, though that one had a Pro-Comp box
VINTAGE MOTORSPORTS
Old 03-18-2006, 04:20 PM
mtpockets,
What has become of your stalling problem? I am sure there are more people than myself interested in the outcome.
Rate This Thread:
