08-01-2006, 10:11 PM
fl
Cobra Make, Engine: Backdraft #486 402r This is my 2nd backdraft.
Brake/taillight problem and yellow dash light
I have a situation where one brake light works and the other tail light goes out when the brake is depressed or something like that. Also yellow light on dash lights intermittantly. Can anyone give me a pointer on this stuff?
Paul
I have been corrupted by perfume and gasoline!!
08-02-2006, 03:32 AM
Paul,
I had exactly the same problem. The light that goes out has a ground problem. Check for a broken wire between the light housing to the car frame.
Paul
08-02-2006, 06:34 AM
Paul,
The yellow light on the dash is probably the fan indicator light. With the fan dash toggle switch in the "automatic" position, the fans come on as you need them.
The tailight MAY also be as simple as a loose bulb in the socket.
If you bought the car "used", contact one of the Backdraft dealers for a manual. It's not the greatest, but should help you on a lot of stuff.
Good luck!
Cheers!
Dave
Dave
08-02-2006, 08:29 AM
CC Member / Sponsor
Paul,
Sometimes the tail light housing contacts move. I have two like this. You may need to take off the light assembly and turn the contacts so that the contacts on the bulb with mate up the the contacts on the tail light housing.
Bill
www.gcperf.com
08-02-2006, 11:28 AM
It's a very common problem to have loose bulbs on the BDR due to the very cheap sockets they use.
For me the fix was to re-inforce the bulb housing with a bondo style product made for plastic
Left is with the filler right is stock.
But in the end, I changed the bulbs for LED's since they are far brighter and don't get hot and melt the plastic like hi-wattage bulbs would.
08-03-2006, 03:47 AM
OK
Cobra Make, Engine: Backdraft #202, Ford Racing 342 Stroker 400 HP
Led Lights
I Tried The Led Bulbs From Auto Zone But The Brake Lights Would Not Light Brighter When The Brakes Were Applied. Do You Have A Bulb # For The Type You Used?
Letitbe
Backdraft #202
08-03-2006, 02:07 PM
LED bulbs (the style from auto shops) are complete crap, you are better off using a candle. You need the LED clusters, a LOT more expensive, but therer is a reason for that.
I used the hardwire 1.85" LED cluster from these guys.
http://www.customdynamics.com/motorcycle_led_bulbs.htm
08-04-2006, 09:23 PM
fl
Rear turn signal
My brake lights do not seem to work at all. Did you use the Led W/ turnsignal setup on those? Also which of the bulbs is tail light and which one is tail/brake? Top or bottom?
Paul
08-05-2006, 08:22 AM
Cobra Make, Engine: BDR 187 Prism Red w/Silver stripes; 427 stroker by Smeding Performance, Tremec TKO600 gearbox
Paul-
Your brake light problem may be the cheesy underdash brake light switch that BDR uses. I had a lot of trouble with mine, so I replaced it with a hydraulic pressure switch in the brake line.
'round Midnight
You'll feel me coming
A new vibration
From afar you'll see me
I'm a sensation!
-Pete Townshend, Tommy
