December 2025
Old 12-04-2006, 12:15 PM
Cobra Make, Engine: Backdraft #101, 392 Ford Motor
David,
My throttle springs on the carb are concentric (one inside the other). I found that the springs would occasionally get tangled with one another causing the throttle to stick like you described. So, I inserted a copper pipe (5/8 in dia, about 3-inches long, I think) outside the inner spring and inside the outer spring. Noe more problemo!
Phil
Old 12-25-2006, 07:25 PM
Boudy's Avatar
Cobra Make, Engine: BDR #42, 425HP 347 - NASA TX, CMC #55 Mustang Road Racer - Legends 37' Chevy Coupe #43 Oval Racer - Honda CRF450R(I'm afraid to race it), 95' Black Lighting Daily Scooter
I've had several cars that I used a LoKar cable on. I found that after a few hundred miles the cable begins to dig into the rubber liner that it rides in. Remedy is to remove all the slack in the cable and remove the axcess at the carb and send a few drops of lube down the cable. This problem was always worse when there was any slack in the cable.
Boudy
