Like Tree2Likes
  • 1 Post By Cashburn
Old 01-25-2007, 08:53 PM
Default Clutch Master Cylinder on a BDR
I have the stock cylinder and was wondering if anyone knows what size fitting is used for the tubing that leads out of it and also into the slave cylinder. I'm thinking about changing the tubing to flexible stainless steel hose so I can reroute it away from the headers.
Old 01-26-2007, 10:31 AM
Dinobyte's Avatar
Cobra Make, Engine: Backdraft #395 from Vintage Motorsports; Valley Ford Specialist 487 FE with a TKO600
I think Reg from BD should be chipping in on this, as this is a major problem with my vehicle as well. What options do we have Reg?
Old 01-26-2007, 11:41 AM
Cashburn's Avatar
Backdraft Racing Dealer
Should be interchangeable with the Wilwood unit:
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 01-26-2007, 10:08 PM
Thanks Jay, I'm assuming the slave cylinder is the same size thread outlet?
Old 01-27-2007, 06:46 AM
Cashburn's Avatar
It depends on the slave. I have not looked at the standard factory slave in a solid year +. We are using Wilwood slaves exclusively at this point.
ront49 likes this.
VINTAGE MOTORSPORTS
Old 01-27-2007, 02:21 PM
Dinobyte's Avatar
They are not compatible. The AN lines are different than those delivered on the Wilwood. Be prepared to jump through hoops (trial and error) to find the correct size, as there is not a standard.
Old 01-27-2007, 03:56 PM
Cashburn's Avatar
Earls Part Numbers:
EAR989544 Clutch - Brake Fitting for
EAR64191918 Clutch - Brake Hose for
Aeroquip Part Numbers:
AERFBM2611 Clutch - Slave Fitting
No flaming hoops to get burned on
ront49 likes this.
VINTAGE MOTORSPORTS
