| 29 |
03-31-2007, 12:19 PM
Cobra Make, Engine: BDR #419 Roush 402R
Everyone check rear diff
Was under my car today cleaning up brake fluid after my slave cylinder gave out.When I was cleaning around the rear diff I noticed the star bolts holding the half shafts to the diff were loose.Four on each side were finger loose and was alittle bit of grease slung up under the car. Luckily I'm still breaking in the car and haven't gotten on it yet. Luckily no noise or problem as a result,at least that I can tell.Make sure every checks these out and I'm going to lock-tite the hell out of these babies.By the way, there are 6 on each side.
#419 roush 402r
03-31-2007, 12:47 PM
MA
Cobra Make, Engine: Sold Backdraft #488 Roush 427R
hawaiicobra, thanks for the heads up.
By the way after your response to one of my posts I went with the 402 also
Peter
04-01-2007, 07:12 AM
nj
Cobra Make, Engine: BDR #188 342R Roush
half shafts
I already had to replace both half shafts and one side took out wheel bearing. I was lucky nothing else happened and Vintage looked over the car while installing the new lsd. This is normal maintenance on these type cars for things to rattle loose. I wish I had a lift so I could inspect more offen. If you see grease on inside of rear wheels you may have a problem.
tom
 No I wouldn't race you, my lug nuts require more tourqe than that thing puts out........
04-01-2007, 11:47 AM
Cobra Make, Engine: BDR 930, 427 Windsor T56
Cobras are like Harleys in the maintenance respect. Things are going to come loose and fall off.
Every 3 to 6 months I put the car up on my lift and inspect everything underneath.
Jim Pomroy
Have Fun!
BDR #930
08 Corvette Coupe
92 Sunburst Yellow Miata
#81 Saturn V Miata Crapcan racer
Panoz GTRA #42
04-01-2007, 12:03 PM
Cobra Make, Engine: Backdraft #395 from Vintage Motorsports; Valley Ford Specialist 487 FE with a TKO600
Good Advice!
04-01-2007, 12:22 PM
I don't know that I would locktite those star bolts since those heads could be tricky and easily strippable. I would check them every 6 months or so instead.
04-01-2007, 12:30 PM
My slave cylinder recently went out as well! Must be a Hawaii thing...
I better check out the rest of the nuts and bolts.
04-01-2007, 05:25 PM
I am there doing this. Two of mine stripped out so I went to the local BMW dealership ordered new bolts. About a 1.50 ea. I had to remove the half shaft boots to get to get access all the bolts. I also am deaaling with grease at rear wheel. Is this leaky seal? and how to repair? Brian
04-01-2007, 05:45 PM
If you have grease at the rear wheel you probably have a small hole in the rubber boot.Large hole if lots of grease. Could have been cut when assembled or road debre hit it. If you can find the hole,clean the boot really good and use a product called "Right Stuff" on the hole.Its a super strong rubber cement type product for gasket repair.Eventually you should put on a new boot though. I had some grease at the center diff. but once I tightened the 6 torx bolts on each side it took care of the problem. How do I get my information on car and engine etc in the upper right of my posts. I'm a computer illiterate.
04-01-2007, 06:48 PM
hawaiicobra,
Go to the top of this page and click on "Quick Links" then select "Edit Profile". When the "Edit Profile" page comes up scroll down to "State", "Cobra Make, Engine", "City" and fill in your info. Scroll to the bottom of that page and select "Save Changes". The changes may not appear until your next post.
Hope this helps.
Cheers!
Dave
Dave
04-04-2007, 08:08 AM
GA
Cobra Make, Engine: BDR - 351 / 385 hp
Socket size?
Would someone please tell me what size / type socket is used on the axle bolts at the differential? Mine are covered with a thick coat of paint & I'd like to get the right socket & check the torque. Thanks.
Speedy
04-04-2007, 10:20 AM
Its an E-12 TORX socket. Make sure you tap it on with a hammer and get a good solid fit. I found that you have to spin the axle around a little bit to get a good position. On the drivers side about 3:00 position worked for me.
04-05-2007, 03:24 AM
How to change a differential out
I found another website that shows you the steps to remove the differential.
http://www.bimmerdiy.com/diy/e36diffswap
Hopefully this helps some of you.
