Old 04-15-2007, 06:58 PM
tamanaco's Avatar
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
Default AC Steering Wheel Cap removal
How does one remove the "AC Steering Wheel Cap" from the steering wheel?
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
Old 04-15-2007, 07:07 PM
Rich A's Avatar
Use a pocket screwdriver.
Insert pocket screwdriver between the cap and the steering wheel.
Pry out the cap alittle at a time working one side then the other side.
You will scratch the steering wheel alittle.
But should buff out.
Old 04-15-2007, 09:35 PM
Rick Parker's Avatar
Be careful not to drop or lose one of the 3 little metal clips that secure the cap to the inner ID of the steering wheel. (they are little!)
Old 04-16-2007, 12:14 AM
Rwillia4's Avatar
If you don't want to scratch the metal go buy a set of bicycle inner tube replacement pry bars from target/walmart/... They come in a pack of three, are made of plastic and ment for prying on metal without doing damage. They have come in handy many times for me in the past.
Old 04-16-2007, 05:44 AM
Cobra Make, Engine: X Everett Morrison, X SPF 140, X SPF1823, currently SPF2778
Use dental floss. Slide the floss behind and pull. Works easy on my car.
Tom
Old 04-16-2007, 08:17 AM
Alfonso's Avatar
Cobra Make, Engine: Backdraft
Default Be careful
I broke my mustang cap, then the second time I did in a different maner: Left hand use a cupping glass while with other hand insert around the small gap a nylon thread (or the dental floss(good idea Tom!)), then use this tie to press into the clips and pull slightly with cupping glass. (I hope you understood me because its a little bit difficoult to explain it in my poor english)
Alfonso
Old 04-16-2007, 12:47 PM
BigGuy's Avatar
Cobra Make, Engine: CSX4xxx, Alum. Shelby 427 w/ Webers,
When replacing the cap try double sided tape. This can be safer than the 0-ring.
The plastic can get brittle though the years.
Jon
Old 04-16-2007, 02:08 PM
hkelley's Avatar
Cobra Make, Engine: SPF #2101 Diamond Ed.; 460
Just removed mine a couple of days ago....My driver's license worked great!
Joe
Old 04-16-2007, 06:11 PM
tamanaco's Avatar
Thank all for the responses...
Old 04-17-2007, 08:20 AM
Hey Alfonso,
What's a cupping glass? Where is Lugo, LU?
Your English is better than many natives on this site.
Brian
Old 04-17-2007, 01:25 PM
uncltodd's Avatar
Cobra Make, Engine: BDR #139, Indigo blue, white stripes, KeithCraft 351W, 315 WHP, 17" Boyd Smoothies, dual roll bars, gunrack, assorted young females
You have caps???
UT
Eagles soar- but weasels don't get sucked into jet engines.
Old 04-18-2007, 01:26 AM
Alfonso's Avatar
Default Brian!
Brian, it's a suction pad (cupping glass its a medical device that we use to make suction, its like a inverted cup with a small piston to extract air). I used it to remove the cap of my old mustang, I've not tried in my BDR but I think I would work in a similar way.
Lugo is a small european town (aprox 100.000) in the north of Spain. The city is rounded by a 1rst century wall (yes! almost 2000 years old) that was declarated World Heritage two years ago. www.muralladelugo.info
Alfonso
Old 04-18-2007, 08:48 AM
Alfonso,
I don't want to hijack this thread but...
I bet you are quite the man around town with that Mustang. I can just see it next to 1,800 year-old buildings and walls. There was a James Bond movie years ago that had one of the Bond girls driving one sorta like yours.
I'd love to see it one day in it's natural surroundings.
Brian
Old 04-18-2007, 02:55 PM
Alfonso's Avatar
Default Brian!
I will send you pics, not on my mustang, I sold it, but in my BDR if, at last, I get to title it in Spain!
Alfonso
Old 04-18-2007, 04:12 PM
Cobra Make, Engine: SPF street roadster
Default cobra emblem for steering wheel?
While we are removing the original AC cap, does anyone know where to get a replacement Cobra cap? Will double stick tape really hold it in place? Ted S.
Old 04-18-2007, 07:58 PM
Finishline has them and yes double sided foam tape will hold it. Thats how mine is on.
Old 04-19-2007, 05:41 PM
tamanaco's Avatar
just took mine off...looking for little clips to fly...what I found was sticky backed foam tape on BDR car #260!
