Old 05-13-2007, 03:15 PM
SD5805's Avatar
Cobra Make, Engine: BDR, 351W, 400 Horses
Default BDR Gastank Weld/ Leak
Hi guys
Has any one had a BDR Gas Tank leak from the actual weld. I had a severe leak coming from the weld causing a large puddle quickly. I'm surprised the the tank is leaking from this weld. I had to empty the tank (by driving) before putting her into the garage. The gage is almost on E and there is still a slow leak. .
My car was purchased in 10/06 with approx. 3200 miles on her.
Any advice or other experiences on this issue will be greatly appreciated
GAry
These cars are way too cool to keep in the garage.
And, Life is too short to worry about gas milage. So, Lets cruise!!MECOOL:
Old 05-13-2007, 05:11 PM
Gatorac's Avatar
Cobra Make, Engine: BDR 930, 427 Windsor T56
Get some stuff called Seals All. You can put it right on the leak even with gas running out. That should stop it until you can get your dealer to fix it.
Jim Pomroy
Have Fun!
BDR #930
08 Corvette Coupe
92 Sunburst Yellow Miata
#81 Saturn V Miata Crapcan racer
Panoz GTRA #42
Old 05-13-2007, 05:21 PM
I have sean seals all work for 15 plus years, it is a permanent fix, once applied no other repairs necessary, cost about $4.00
Old 05-13-2007, 06:07 PM
Do you have a stainless steel tank or the newer aluminum ones?
Old 05-13-2007, 11:41 PM
SD5805's Avatar
I have the newer aluminum gas tank
Old 05-14-2007, 08:44 PM
I had two leaks, at the outgoing tube which I fixed with seals all and another at one of the welds at bottom center of tank. I decided to change diff gears and pulled the tank. It was pretty easy, did it by myself. When the tank was out I had a buddy weld it. The seals all was holding fine after two years though. But since the tank came out anyway I just welded it.
Old 05-15-2007, 10:05 AM
SD5805's Avatar
its too bad we have to do this in the first place being a new car replica or not. This is a basic function of te vehicle and should alway be perfect if new.
Old 05-15-2007, 10:54 AM
Seals All? I will have to look into that, I've used JB Weld with great success in the past. BUT, the tank has to be removed and kept dry until the the JB sets up.
Couldn't find a link, Google returned "Seals, the top predator" among other misleading links. ?????
Old 05-15-2007, 11:11 AM
BDR298's Avatar
Cobra Make, Engine: Backdraft #298, 302 5 speed
I had a small leak at one of the welds. Just enough to make the garage really smell. I had about 500 miles on the car when it showed up.
I took it to a my friends race shop and they fixed it. They took the tank out and welded it.
Old 05-15-2007, 11:17 AM
pmfranke's Avatar
Cobra Make, Engine: B&B 351/402 Fi roller everything
Seal-all made by the people who make GOOP most WALMARTS have it. gas resistant sealer glue. Great stuff , a must have in tool kits. www.seal-all.com
the older i get the faster i was.
Old 05-19-2007, 03:44 AM
SD5805's Avatar
thanks guys
Old 05-19-2007, 07:42 PM
Cobra Make, Engine: Backdraft #486 402r This is my 2nd backdraft.
Default So thats why my garage is stinking up my house!!``
I read this thread and checked and I have a leak so small it does not drip on the floor, just stinks the place up. Will fix it tomorrow.
Thanks for the input.
Paul
I have been corrupted by perfume and gasoline!!
Old 05-20-2007, 11:50 AM
SD5805's Avatar
Its unknown why they do this, but it one thing that backdraft must address. Its such a basic automobile function there should be no excuse for this.
Out of my gas tank issue however, I'm very happy with my ackdraft
Old 05-20-2007, 02:34 PM
BEH BEH is offline
The leak is probaly from porosity in the weld.
This is a weld defect.
I don't understand why BDR isn't repairing it under warranty.
If there is a history of weld problems, then all tanks should be pressure tested at the factory, either BDR or the supplier of the tanks.
Sealers I would think is a temporary fix or something you would use in a old junker, not a new vehicle.
Old 05-20-2007, 05:04 PM
Plastick tank to stainless tank to aluminuim, how much weight savings is realized. In defense of BDR superformances have the same issues, but I agree with what they cost and risks involved the welds should be soaped with couple inches of water pressure. I would never put one of these tanks under more than inches of water pressure, you might very well have a grenade on your hands.
Old 05-20-2007, 06:42 PM
The stainless steel tank has to go about 30 - 40 lbs.... easy. Had mine out this winter to fix the sender unit and its heavy. Aluminum has to be at least half the weight. I would think they would be putting them under some type of pressure test for at least an hour or so with a gauge. That would find the leaks.
Old 05-20-2007, 07:09 PM
SD5805's Avatar
BEH,
I must say that Jay at Vintage say he going to replace the tank for me propbably a warranty issue. If Anything He been one hell of a support
GAry
Old 05-20-2007, 08:10 PM
Cashburn's Avatar
Backdraft Racing Dealer
Originally Posted by SD5805
BEH,
GAry
Yes, as I said... happy to take care of it when we are in the shop, sorry for going to an event all weekend
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 05-21-2007, 04:47 AM
6t8stang's Avatar
Cobra Make, Engine: BDR#436 - 351W - 450HP / 429TQ
On that note...it was good to see & talk to you again Jay...at both events!
Eric
Old 05-21-2007, 07:56 AM
SD5805's Avatar
Jay,
Hope al1 events went well Let me know how the BDRs looked. If you brought the sterling gray car, That one is HOT
See Ya Soon
