Old 06-16-2007, 03:12 AM
Cobra Make, Engine: BDR #188 342R Roush
Question alignment
I have a bad shake in front end and need help.
I took tires off and checked balance on both. both are ok.
When dealer looked at tires he said pass side tire is cupped real bad. He said this is most likely my problem. I just got a $400.00 alignment done when the car was at vintage in sping with about 300 miles on it since. When you jump on the car and at higher speeds it now seems to get real loose on the front end almost where you think your going to loose it.
I guess I should get it reaigned and need proper specs for a street driver not a track car.
Can someone tell me the correct specs for this car?
Tony, Reg?
thanks
tom
No I wouldn't race you, my lug nuts require more tourqe than that thing puts out........
