Old 08-12-2007, 08:41 PM
BDR530's Avatar
Cobra Make, Engine: Backdraft Racing - Silver Gray w/ Titanium Silver Stripes, 351W (435HP), TKO 500
Question Turn signal not illuminating brighter?
I'm having a problem with my driver's side turn signal. When it flashes, it goes off and then back on. The correct illumination should be that the light is always on, and gets BRIGHTER when the signal is flashing (this is how the passenger turn signal illuminates). Anyone else having this problem, and/or know how to fix it?
Old 08-12-2007, 11:27 PM
wtm442's Avatar
Beam Me Up Scottie
Is the bulb a dual filament with one of the filaments burned out?
Warren
CHANMADD's Avatar
You have bad grounds!
Old 08-13-2007, 09:56 AM
BDR530's Avatar
It is a dual filament bulb but both filaments look good. I'll check the ground tonight.
Old 08-13-2007, 10:11 AM
wtm442's Avatar
Beam Me Up Scottie
"Looking good" is not a test of functionality. Hold the base of the bulb securely and tap the bulb and see if either filaments "wiggle". Or swap the bulb to the other side and see what happens. If the bulb is OK on the other side, it could be the bad ground as CHANMADD mentioned. Also check for corrosion on the spring loaded terminals in the socket.
Warren
Old 08-13-2007, 10:17 AM
Cobra Make, Engine: BDR 559. 410 Stroker 72 block AFR205 Heads, Solid roller lifters, Comp Cams XR286, Eagle 4" stroke internally balanced with chevy journals, Oliver rods, Probe Forged pistons, Mighty Demon, Super Victor, MSD Digital 6.....
I have had the same issue with my first BDR, It was a bad/loose ground
BDR 559
Indigo Blue, White Stripes
SBF 410
TKO 600 .82 OD (Road Race)
HP= Enough!!
