  #21 (permalink)
Old 08-15-2007, 01:48 PM
uncltodd's Avatar
Cobra Make, Engine: BDR #139, Indigo blue, white stripes, KeithCraft 351W, 315 WHP, 17" Boyd Smoothies, dual roll bars, gunrack, assorted young females
Cashburn, I'm sorry, I'm sorry, but you ripped the bandage off an old wound...
"Owner's Manual?"
I would dearly love to have such a thing.
Happy birthday to #139, I took delivery 3 years ago.
UT
Eagles soar- but weasels don't get sucked into jet engines.
  #22 (permalink)
Old 08-16-2007, 05:33 PM
Rwillia4's Avatar
Cobra Make, Engine: BDR #455, KC427W, TWM-FI
Jay is correct.
DOT 5 is not a good solution, two reasons: 1) is doesn't mix with the previous DOT3/4 in the system (which is difficult to remove from the system without fully removing the parts and cleaning seals,... 2) DOT 5 is NOT compatible with the o-rings and seals designed for a DOT 3/4 system
Don't fully understand? do a google search for yourself: "dot 4 change to dot 5". You will notice a trend for yourself. End of story: DOT 5 in your DOT 4 designed system is bad news. Unless you want to revisit this issue again a year or so down the line to replace more than fluid.
The advantage of an open forum is that everyone is entitled to an opinion; the disadvantage is you have to wade thru the "filler" to get a solution.
Uncltodd- do you still have your ride? I can make a copy of my manual and send it to you; PM me. You are not missing much if you have been at it for 3 years.
  #23 (permalink)
Old 08-16-2007, 06:05 PM
my observations study, interviews, first hand experience, and research on clutch hydraulics aren't "filler"...my man, and you are entitled to your opinion. I will be sure to scutinize your "filler" in the future...Earlier in my life I owned a sucessful tranmission repair facility for 10 years, and replaced far more clutch hydraulic systems in my time than I am sure most people on this forum...my info isn't from "google" searches...and jaybird is not the expert on everything.
b/d's have an extreme heat problem under the hood. dot 3/4 is not a solution for this....a clutch system is an easy flush.....don't confuse it with a braking system....a year from now, I will love to see if this "heat shield" folks are selling really works, I hope it does....not enough time yet though....
for those of little faith, as I said before...keep using your dot3/4...
keep up the good karma dude!
  #24 (permalink)
Old 08-16-2007, 10:20 PM
Rwillia4's Avatar
Rocket- look at a previous post that is more about brakes but still good info
Brake fluid, somewhat Backdraft specific
  #25 (permalink)
Old 08-17-2007, 06:57 AM
Cobra Make, Engine: BDR #188 342R Roush
Thumbs up clutch and brake fluid
I read this and maybe it will help others. I'm going to do slave next weekend due to time allowed but should be no problems with the help I got from here and Vintage Motorsports.
Thanks all to advised.
tom
Brake Fluids
Thanks to Dave Zeckhausen :
Lets look at what the DOT ratings mean. The table below shows the MINIMUM wet and dry boiling points for DOT 2, 3, 4, and 5 brake fluid in degrees fahrenheit.
DOT 2 DOT 3 DOT 4 DOT 5
Dry Boiling point 374 401 446 500
Wet boiling point 284 311 356
The DOT 2 spec is for drum brakes and is obsolete. If you have any DOT 2 in your garage, throw it away! DOT 5 is for silicone brake fluid. Silicone brake fluid (DOT 5) should be avoided because it is not compatible with regular brake fluid, it is hard to pour without introducing bubbles and thus results in soft pedal feel, and moisture still gets into your system and will pool in low areas like your calipers and encourage rapid corrosion. STAY AWAY!
That leaves DOT 3 and DOT 4 fluids. These fluids are compatible with each other and may be interchanged or mixed with no ill effects.
Let's look at some popular brake fluids and their boiling points:
Fluid DRY WET
Castrol LMA DOT 3/4 446 311
Ford Heavy Duty DOT 3 550 290
ATE Super Blue Racing 536 392
ATE TYP 200 536 392
Motul Racing 600 585 421
Castrol SRF 590 518
Performance Friction 550 284
Castrol LMA is very good at rejecting moisture and may be kept in your brake system for a couple years. The LMA stands for "Low Moisture Activity". This is the minimum quality stuff that I would use in my Impala. It comes in plastic containers which do not have a long shelf life. Don't buy lots of this stuff at a time because moisture can make its way through the plastic containers.
Ford Heavy Duty DOT 3 is VERY inexpensive and is popular among racers because of its excellent dry boiling point. It absorbs moisture quickly, but the racers don't care since they change their fluid frequently. Comes in metal cans so it may be stored. I would not use this in my Impala for the street.
ATE Super Blue Racing and ATE TYP 200 are the same brake fluid in two different colors (blue and amber, respectively). BMW recommends this brake fluid for their street cars because it, like Castrol LMA, absorbs moisture very slowly. The advantage over LMA is that ATE has a much better wet boiling point. You can put this stuff in your car and forget about it for a long time. An excellent choice for a weekend track car which also sees regular street duty. Comes in metal cans. This is what I use in all my street cars.
Motul Racing 600 is a very exotic and expensive synthetic fluid with high wet and dry boiling points. I use this exclusively in my race cars. Too expensive for the street and requires frequent changing due to its hygroscopic nature. Sold in plastic bottles. It is not suitable for the street because it absorbs moisture quickly.
Castrol SRF is a hyper-exotic and hyper-expensive brake fluid that is generally used by wealthy Porsche owners at track events. I've seen prices of $78 per liter for this stuff. Sold in metal cans. I can't afford this stuff!
Performance Friction High Performance DOT 3 has a good dry boiling point but a crummy wet boiling point. It comes in metal cans which is good for shelf life and sells for $7.87 per 16 ounce container. If you are even considering this fluid, I would go with the cheaper Ford Heavy Duty DOT 3. In either case, change this fluid frequently due to the poor wet boiling point.
Thanks to Leigh Smith for the following information on the impact of moisture content in brake fluid :
The amount of moisture in brake fluid definitely affects its performance. The big problem is it is absorbs moisture quickly. Over a relatively short period of time brake fluid will absorb moisture from the air. SAE field tests have shown that the average one year old car has 2% moisture in the fluid. A random test of vehicles in the U.S. showed an average water content of 2.6% for vehicles with an average age of 8 years. And 25% of these vehicles had water content greater than 4%.
As water content in brake fluid increases over time, the boiling point decreases. Fluid with a reduced boiling point (or high water content) can create vapor by boiling in the caliper, or wheel cylinder. The result is sudden brake failure. And water in the brake fluid can contribute to corrosion of parts such as steel pistons and ABS modulators.
The end result is even though DOT 3 fluid is "rated" at greater than 401oF, in the typical 3 to 4 year old car with 3 to 4% moisture content, it could boil under 300oF. And if it has got more than 4% moisture, you may as well be running straight water!
Moral: Flush your brake fluid every year or so. But only if you would like it to work well scarcely an inch away from those toasty 500oF rotors on your SHO during a couple of hard stops! Or would you rather have a squishy pedal?
Technical data courtesy of Leica Refractometers. www.leica-ead.com.
No I wouldn't race you, my lug nuts require more tourqe than that thing puts out........
Rate This Thread:
