December 2025
Like Tree1Likes
  • 1 Post By cycleguy55
Old 09-02-2007, 08:47 AM
dlampe's Avatar
If they are 17 in, you really need to start at 30 -32 pounds and check them hot with a target of 36-37 pounds. If they are 15in then the target heat range is 30 pounds as a general rule. If that doesn't help, you will need more swaybar in the back or less in the front, heaveir springs in the back or less in the front. You might try more pressure in the rear but if it is severe, thats probably not going to get the job done.
High Maintenance Racing Team
Run & Gun 2003 - 2013
