Old 09-05-2007, 03:44 PM
Cobra Make, Engine: Backdraft 427 Stroker, Sterling Gray/Silver
Default BDR fuel filler neck - WARNING
FYI-
I was working on my BDR last week and noticed that not one of the 5mm screws (there are about 6-7) securing the fuel filler ring to the body had a nut or washer.
I reached through the rear wheel well (with the wheel off) and was able to pop each one out with my finger. They are the countersunk screws you can see around the fuel filler cap.
I'm sure I am an unique case, but it can't hurt to check. I sincerely doubt all vibrated loose by themselves.
Better safe than sorry.
Old 09-05-2007, 04:36 PM
thank you for the tip(observation)...most likely that is the same case with other b/d's...
things like this are helpful on this forum...no debate needed!
Old 09-05-2007, 05:43 PM
Cobra Make, Engine: BDR 559. 410 Stroker 72 block AFR205 Heads, Solid roller lifters, Comp Cams XR286, Eagle 4" stroke internally balanced with chevy journals, Oliver rods, Probe Forged pistons, Mighty Demon, Super Victor, MSD Digital 6.....
Mine were loose and it's a new car...
BDR 559
Indigo Blue, White Stripes
SBF 410
TKO 600 .82 OD (Road Race)
HP= Enough!!
Old 09-06-2007, 11:34 AM
Gun Doc's Avatar
Cobra Make, Engine: BDR#499 351W with Webers
I have had issues with some of the hardware on #499 as well. It seems that Backdraft uses common flat nuts and star washers on many of the non-load bearing aplications throughout the car.
I went to the local Fasten-All dealer and bought a bag of Ny-lock nuts (100ea) for $4.00 and begun replacing most of the flat nuts. I don't know why Backdraft uses flat nuts abd star washers on cars that vibrate as much as these do...
Gun Doc
Old 09-06-2007, 01:24 PM
Blittleton's Avatar
CC Member / Sponsor
It is always good practice to use nylon lock nuts and lock washers. We have recently overhauled out parts bin and now have really nice hardware that shouldn't come loose. I also using a crimp nut on the headers/sidepipe flange. This is really nice that we haven't had any come loose as of yet.
Bill
www.gcperf.com
Old 09-08-2007, 02:39 PM
uncltodd's Avatar
Cobra Make, Engine: BDR #139, Indigo blue, white stripes, KeithCraft 351W, 315 WHP, 17" Boyd Smoothies, dual roll bars, gunrack, assorted young females
I always post my build #139 it helps.
Eagles soar- but weasels don't get sucked into jet engines.
