03-23-2008, 01:48 PM
Cobra Make, Engine: #42 BDR w/ a 408 KCM stroker
Clutch Master cylinder
Okay working through the bugs, I noticed a small leak of clutch fluid by the pedals, upon inspection the boot was torn and fluid was leaking out. Does this mean my master cylinder is bad? also what master cylinder do these cars use for the clutch? mine is an early car #42.
2006 King Ranch F150 Supercrew
Personal vehicles-2007 Escape
2004 BDR #42 with a 408 Keith Craft Stroker, Crimson with Silver stripes
03-23-2008, 02:45 PM
usually if the fluid is leaking out of the boot, the seals inside are bad. Does BDR not use an aftermarket like Wilwood or similar? If so, the rebuild kits are like $20. I have to rebuild the ones in my race car annually. If it is a wilwood type, you can find a local dirt track shop for a rebuild locally. daymotorsports is in Tyler TX which I don't think is too far from you.
i would assume you have somehting like this:
http://www.daymotorsports.com/product/869/c/S2/
 Bagram AF Afghanistan
03-23-2008, 03:25 PM
No it's a regular one, J Ross did have a tilton he let me get off him pretty cheap so I have to change the line but everything else matches up
03-23-2008, 07:51 PM
VW Rabbit GTI 83-84 (I think I remember that from a previous post)
03-23-2008, 08:44 PM
got a new Tilton from a freind, a little larger but fits fine, had to re-route the line but should be fine, we will see in the morning
03-24-2008, 08:41 AM
Cobra Make, Engine: Cobra-less
My car is build #128 and I got a replacement from Summit. No rebuild kit available.
Cobras Gone But Not Forgotten
04-16-2008, 10:09 PM
the clutch master on mine (#89) is a Wilwood... but I suppose one of the previous owners could've replaced it.
R. Smith
Santa Clarita, CA
04-17-2008, 08:02 PM
Cobra Make, Engine: BDR #491, Red with Black Stripes, 438 Windsor by Keith Craft Racing dynoed at 640hp, Street and Race Prepped.
Patrick, a Wilood 3/4 master will work perfectly. You can get them at Summit or Jegs.
Bests, James
Radical Roadsters of Texas LLC
www.radicalroadsters.com
Backdraft Racing Dealer
281-804-5730
Watch out! You may get BIT!!!
04-20-2008, 10:28 AM
OK
Cobra Make, Engine: BDR #139, Indigo blue, white stripes, KeithCraft 351W, 315 WHP, 17" Boyd Smoothies, dual roll bars, gunrack, assorted young females
FST FOX, the guys at KCMotorsports there in Plano should be familiar with BDR's, front to back. They were very cordial to me in '04 under... adverse circumstances.
Say Hi! to #42 for me, she was my first love.
UT
Eagles soar- but weasels don't get sucked into jet engines.
