Old 06-12-2008, 06:24 PM
tamanaco's Avatar
Cobra Make, Engine: BDR #260 w/ 347 stroker, Canfield 195 cc heads, prosystems carb on a VicJr, Comp roller cam
Default front rotor wheel stud replacement
ok...got one stud on a front rotor that has no threads left after a very difficult wheel lug nut removal. It looks as if the stud can be screwed out of these BMW rotors. my questions are 1. does BMW sell replacements studs? is this a left hand thread into the rotor? best way to remove the stripped stud? How to install the new stud?
BDR#260...21.6K miles logged as of 4/2018
www.motorheadsohio.com We are an engine machine shop, specializing in crankshafts!
47 years of doing business an going strong! stop on by for a personal tour of the shop
Old 06-12-2008, 06:37 PM
Cashburn's Avatar
Backdraft Racing Dealer
You can get a full set pretty cheap: http://cgi.ebay.com/ebaymotors/_Car-...m200231085461&
The factory BMW setup has male nuts/studs, they were converted by BDR to the stud with standard female lugs for the bolt on wheels.
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
Old 06-13-2008, 09:46 AM
Cobra Make, Engine: BDR 187 Prism Red w/Silver stripes; 427 stroker by Smeding Performance, Tremec TKO600 gearbox
There are many aftermarket sources for BMW wheel studs. Just do a Google search. Or, you can just get standard BMW lug bolts from a BMW dealer or other parts source like I did. From the dealer they're pretty expensive, though. I would recommend stud replacement on any BDR. The ones they come with are not very good, at least on the early cars.
'round Midnight
You'll feel me coming
A new vibration
From afar you'll see me
I'm a sensation!
-Pete Townshend, Tommy
Old 06-13-2008, 03:37 PM
tamanaco's Avatar
Jay thanks for the link...got my short term fix. Yep R_M, the BDR OEM's don't look like the best.
Old 06-18-2008, 05:40 PM
MrMagoo's Avatar
Cobra Make, Engine: Performance Cars Venom 427 Keith Craft 408 Stroker
Send a message via AIM to MrMagoo
Just got some black chrome-moly studs from bimmerworld.com...
They have a bullet nose for easy seating of the lug. Even their short ones are quite long (>70mm) and they use open lugs. I like the way they look. You tighten them with a hex key, which is a lot better than the screwdrivers type.
If I can see you, I'm too close
Rate This Thread:
