February 2026
Old 08-15-2008, 06:38 AM
Mac VABCH's Avatar
Cobra Make, Engine: BDR #250
Bailey,
Unfortunately I don't think I will be back in time from Kenya. I am still holding out hope that there is a slim possibility that it will work out. I saw a your new toy!!! I'm jealous give hell...Mac
Old 08-15-2008, 11:22 AM
MrMagoo's Avatar
Cobra Make, Engine: Performance Cars Venom 427 Keith Craft 408 Stroker
Send a message via AIM to MrMagoo
I use a syringe (like you get in a drug store for administering medicine) with clear vinyl tubing attached to the end. It's still a pain. Would be nice to have it mounted on the firewall or something.
That was really interesting about the merits of a push versus pull type cylinders. I am using a push now, but I saw a photo of a pull type attached to a bracket on the tranny and it *looked* like a good way to go, but now with the seal direction thing I guess its not. The push works fine, but the alignment of the shaft and the fork is hard to get straight and you have to worry about the bellhousing getting in the way.
I guess there is a reason that manufactures use hydraulic throwout bearings.
If I can see you, I'm too close
Old 08-15-2008, 11:41 AM
Cobra Make, Engine: BDR #212, 392 stroker
I remove the louver/vent on the drivers side and can get to both resevoirs easliy.
Ned
Old 08-16-2008, 10:32 AM
Cobra Make, Engine: BDR #19 351W 3550 tremec
Send a message via Yahoo to tober127
I do both, pulling the louver on the driver side is really quick and easy then I use a syringe that I found at a pet store to give meds. to dogs and cats. The whole vile hold the same amount as the resevior.
