Old 03-05-2003, 02:51 PM
Cobra Make, Engine: CSX Cars
I ran out as the last one shipped out on Monday. I am in the process of making a batch of 16. they will be done in a couple of weeks.
Joe, I would be affraid to bring the TV down to your area as it will be in the back seat of my car. With all of those special drivers you have I do not want it flying through the front windsheild.
I will let everyone know when they are done. Pete we still would like to meet you....
Allan
Old 03-05-2003, 06:39 PM
Pete C's Avatar
Cobra Make, Engine: ERA 427 SC #004 (Original ERA?)
Allen,
I'd like to meet you too. Do you mean at Turk's on Saturday? If so, and I'm not working on my new track car I'll pop by!!
Cheers, Pete
Drive it like you stole it!
Old 03-05-2003, 08:44 PM
Turk promissed a great lunch, it will however include the installtion of a 9 volt baterry and 9 volt motor to power his car.
Allan Sat is fine with me.........
Old 03-05-2003, 09:36 PM
Pete current plan for 10-11 am on Sat.
Old 03-26-2003, 10:09 AM
427SSSS's Avatar
Cobra Make, Engine: Hi-tech body/frame, 427engined FF5/302engined FF5 Bennett 289 & 427 rolling chassis
Default How tight do your pins fit the holes?
OK the spinner removal tool works great, but, but, but, then removing the wheel from the pins????
Just how tight is the fit?
I got the pin-alignment tool from Trigo to set the pins right prior to mounting wheel, but the tolerance between the pins and the holes in the Compomotive wheels is so close, they are a bear to remove. (after fighting for two days, I still can only get the right rear wheel on with only four pins, if I put the fifth pin in, there is no way the wheel will go over all five pins)
Watching the Formula One, and Cart races this weekend (arn't they pin drives), the pit crews removed/replaced the wheels with ease. The tolerance on the pins/holes can't be as close as mine.
Anyone hone out the wheel holes to make the install/removal process easier?
Albert Einstein
Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.
Old 03-26-2003, 11:25 AM
Pete C's Avatar
Wayne,
Are the studs straight? Will the pin fit into the 5th hole when free of the adapter? The first time I mounted my trigo wheels it was a bear. After driving on them, the studs realigned and removal and remount was a piece of cake. I did make a problem for myself once when I re torqued the pins. Due to the anti seize, the drive slipped out of the head of the pin and flared the end slightly, but enough so that remount was a problem. Did you flare the head while you torqued it in place? If so, it will be difficult to insert the pin in the hole even when not mounted on the studs.
Cheers, Pete
Old 03-26-2003, 11:55 AM
For those of you who have been waiting I will have a hand full of them on Staurday at the BACC breakfast.
Allan
Old 03-26-2003, 12:03 PM
Pete C's Avatar
Allan, Did you leave one for me at Turks? If so he probably sold it at the dealership with a 400% mark up! Sheesh!
Cheers, Pete
PS Will you be at the NorCal open track at Thunderhill? Perhaps I could pick it up there?
Old 03-26-2003, 12:50 PM
427SSSS's Avatar
Pete C'
{{I got the pin-alignment tool from Trigo to set the pins right prior to mounting wheel}}
Yes the pin does fit any of the holes on it's own.
I just don't understand why it needs to be such a tight fit, the other three wheels did fit, but barely.
Seems to me the pins could be made out of a harder material, when tapping them into alignment so they will fit thru the "pin-alignment tool" from Trigo they can be damaged really easy, after the first couple of taps, I started using a block of wood btwn the hammer and the pin so as to not dent/damage the pins.
Albert Einstein
Old 01-05-2009, 02:25 PM
I have had a few request for some more spinner tools, I would prefer to make a batch of six in lieu of one or two. If you have any interest please let me know. The price has gone up to $85 each.
Allan
A happy SAI customer
Cobra Make & Engine: Continuation Series Shelby Cobra, CSX 7034 the most accurately detailed Continuation Cobra to original specification since the demise of CSX 4027.
Old 01-05-2009, 02:52 PM
Got the Bug's Avatar
Allan,
I'd like to buy one. Please send me a PM or email with the details and I'll shoot you a check.
Thanks.
Doug
Old 01-05-2009, 03:04 PM
RodKnock's Avatar
Allan,
Same here. Shoot me a PM or email with the details. Thank you.
  #33 (permalink)
Old 01-06-2009, 01:09 AM
Road Snake's Avatar
Cobra Make, Engine: 396ci 460hp SPF #1072-Titanium
Allan,
Me too!
Thanks.
Dennis
The Road Snake.
Dennis, SPF #1072
  #34 (permalink)
Old 01-06-2009, 09:58 AM
Allan,
I would like one.
Dave V
  #35 (permalink)
Old 01-06-2009, 10:45 AM
All,
Please send me an e-mail at cranebldr at aol dot com
I will send the info once I get your e-mail
Allan
