Old 10-31-2008, 01:32 PM
289fia_cobra's Avatar
Default Radiator issues... recommendations
As winter approaches in full force, I'll be taking out my Ron Davis Radiator; this will be the 3rd time. It has a leak again. RD fixed it for free once. I don't know exactly where the leak is, but if past history from the previous 2 times are an indication, I would bet good money it's in the upper right corner as in the previous 2. RD will charge me if I send it to them again, but they are based out of AZ. Shipping to and from would already be about $100.
I know RD has a reputation but this is getting old. The first time, on the first radiator, I tried to get a shop to fix it and they totally messed it up. I took blame for the leak because I hard-mounted it to the frame.
On radiator #2, I used more cushioning. It leaked but then when RD got the radiator, they spoted some electroysis. While I have two large ground straps from the engine to the frame, I made sure upon remounting the radiator, that it was not touching the frame as to ground itself and become a conductor. Upon final mounting, and lots of insulation and a custom bracket I fabbed up, I took my multimeter and did not register ANY continuity to the frame.
Well, it started to leak again; first a very tiny bit. Then a little more. I tried some alumaseal but this only stopped it for about 2 -3 weeks. Then it started up again.
So here's my thoughts:
1) Find a shop that know's how to repair this radiator. I mean they actually must remove the tank sides to reveal all the welds to the horizontal tubes; I highly suspect this is where I'll find the problem. Hoping repairs are no more than $200.
2) Just buy a less expensive radiator for $300. A 347CID motor shouldn't get hot enough to utilize a RD radiator of this size. Most people have used Mustang radiators for similar sized engines with no problems. An Afco or Be-Cool or even a Griffen radiator would likely be ok. I can even get a fairly inexpensive one straight from Factory Five.
If some of you know of a GOOD shop with fair prices (I'm not looking for the cheapest, just someone that knows how to repair this kind of radiator), I'll at least call them for a quote. I'll be able to bring them the radiator for their inspection.
TIA,
Herman
My Build Site
Old 10-31-2008, 01:51 PM
tkb289's Avatar
Herman,
Try Mountain View Radiator on El Camino ( 650-968-9146 ). I had some work done on a radiator in a '65 fastback I had some years ago, they did a great job. Thier motto is ... ' a great place to take a leak' ... now how can you go wrong with that !
- Tim
Old 10-31-2008, 08:53 PM
PANAVIA's Avatar
Herman, you may have more luck as tim says "locally". as long as you get a 4 core or better you should be OK with a 347 in your FF.
Old 11-01-2008, 01:07 PM
WAs pricing out the AFCO at Factory Five RAcing: only $225+shipping so call it about $250 shipped. It's awfully tempting. ...
My Build Site
