Go Back   Club Cobra > Club Forums > Bowtie Snakes
December 2025
Old 03-05-2002, 09:53 PM
Default vette front suspension
I have a complete vette front suspension I am removing from my E_M iif someone is needing one. It is powdercoated black and the calipers are red. aluminum is bare. $500.00
Old 03-13-2002, 08:06 PM
Cobra Make, Engine: None yet
Cobra2,
When you finish your front end swap,how about some before and after pics? I have what your getting rid of and was curious how it will look with the narrower one.
Thanks,
Tom
Old 03-13-2002, 10:37 PM
BT SNAKE's Avatar
Cobra Make, Engine: Midstates Cobra, RFGT40
Thumbs up
Cobra2,
I have 88 vette suspension front and back. I love it !
It really makes a difference to me as how the car handles.
I did modify the front suspension by removing the
large leaf spring and putting in coil overs that adjust.
I am also running 245 / 50 - 16 tires too and they don't
rub the outer fender. I have the compmotive wheels.
So I guess I'm curoius as to why you would give
up on the vette suspension. What type are you going to
use instead ?
Hersh
Old 03-13-2002, 10:39 PM
Will do. i think it will bring the wheels in about 1" on each side.
Old 03-13-2002, 10:42 PM
BTSnake, not giving up on it just switching to the '87 year that is narrower.
Old 03-15-2002, 07:52 PM
Cobra2,
Couldn't you have brought them in by changing your backspacing of the front wheels? Seems like that would've been the easier route unless you had access to another frt. end. Are you continueing with the monoleaf or converting to coilovers?
Old 03-15-2002, 09:00 PM
Ratsnake, I'm using the same monoleaf spring from vettebrakes that is with the newer front end on the car now. It is common knowledge that the earlier front suspension (84 to 87) works best with the E-M kit, but I had access to the later one when I built the car. I thought it would be just a matter of changing one or more componets to go to the earlier front but found that nothing is interchangeable cept the rack and maybe the swaybar. The earlier front does use single piston calipers, I guess this could be concidered a downgrade.
Old 04-14-2002, 10:26 PM
Sold my cobra and the front end with it. Guess I'm out of here..*S* Anyone wanna be the boss of bowtie snakes?
