January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 08-09-2001, 02:21 PM
Question Alignment Settings
I didn't build my CRL so I'm not sure what the front suspension is from it has a static toe-out condition so I want to get it on an alignment machine. Does anyone know what the toe should be set at? Is the camber adjustable? If so what should it be set at. I was told I have a Pinto steering column, can I assume a Pinto front suspension?
Dave
Old 08-09-2001, 03:52 PM
dscott's Avatar
Cobra Make, Engine: Owner, Classic Roadsters II
Dave, All the CR cars use the Mustang II front suspension. Doesn't matter if it's tubular or stock they all use the same alignment specs which are as follows.
Caster 3.75 degree +/- .5 degree
Camber 3/8 degree +/- 1/8 degree
Toe-in .03 - .06 (1/32 in. to 2/32 in.)
Don
Old 08-09-2001, 03:59 PM
Talking I'm outa here
Thanks Don, I have a hardcopy of your specs. and am heading out to Harolds Fram Shop.......
