Old 05-16-2010, 06:45 PM
onefastmustang's Avatar
Default Short throw shifter
I really like the short throw shifter in my Mustang so I have decided to put one in my Cobra. Does anyone know if the standard T5 shifter will fit in the T5Z transmission? I expect it will but I thought I would confirm before I spend the cash and find out it doesn't..
TIA
Old 05-17-2010, 04:13 AM
Double Venom's Avatar
Mike,
You've got me on that one-haven't seen the "Z" but I would think it would!
Old 05-17-2010, 04:21 AM
Yep, it will work.
I sell Hurst, Pro 5.0, Steeda, and McLeod shifters. If you need one, I can help you choose one.
Old 05-17-2010, 06:09 AM
CobraEd's Avatar
The T5Z comes from the factory (Ford Racing) with an awsome short throw shifter. It is not at all like the standard Mustang shifter.
________
________
Old 05-17-2010, 08:33 AM
I don't have a standard shifter in my mustang. I have the Steeda Tri-Ax in there. I found a source for a new Steeda for 50 bucks so I guess I will grab it and throw it in.
Thanks All.
Old 05-17-2010, 08:35 AM
My T5Z was a pull from a Cobra. Unfortunately it is not the stock shifter but it looks like a Hurst shifter and I don't really care for it too much.
Old 05-17-2010, 10:02 AM
A little known fact is that shifter will also increase your fuel mileage by 6-7MPG.
Craig
Old 05-17-2010, 11:37 AM
Hmm.. I googled that and could not find any supporting facts..
Old 05-17-2010, 03:36 PM
snakebitekit's Avatar
Cobra Make, Engine: ERA FIA #2119
Try looking on SNOPES
Old 05-19-2010, 04:54 AM
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
I have a Tremec 5 speed, I cut the shifter down and re-drilled two holes to make it fit. It's shifts quick. But. when it's cold outside the shift boot gets sfiff and makes it pop out of gear so I have to hold it in gear for a few miles.
