Old 05-16-2010, 06:45 PM
onefastmustang's Avatar
Cobra Make, Engine: CRII with a Stroked Windsor
Default Short throw shifter
I really like the short throw shifter in my Mustang so I have decided to put one in my Cobra. Does anyone know if the standard T5 shifter will fit in the T5Z transmission? I expect it will but I thought I would confirm before I spend the cash and find out it doesn't..
TIA
Mike
Old 05-17-2010, 04:13 AM
Double Venom's Avatar
Mike,
You've got me on that one-haven't seen the "Z" but I would think it would!
Old 05-17-2010, 04:21 AM
Yep, it will work.
I sell Hurst, Pro 5.0, Steeda, and McLeod shifters. If you need one, I can help you choose one.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
Old 05-17-2010, 06:09 AM
CobraEd's Avatar
The T5Z comes from the factory (Ford Racing) with an awsome short throw shifter. It is not at all like the standard Mustang shifter.
LIFE IS TOO SHORT TO WORRY ABOUT GOOD GAS MILEAGE
________
Utinam logica falsa tuam philosophiam totam suffodiant!
________
Old 05-17-2010, 08:33 AM
I don't have a standard shifter in my mustang. I have the Steeda Tri-Ax in there. I found a source for a new Steeda for 50 bucks so I guess I will grab it and throw it in.
Thanks All.
Old 05-17-2010, 08:35 AM
My T5Z was a pull from a Cobra. Unfortunately it is not the stock shifter but it looks like a Hurst shifter and I don't really care for it too much.
Old 05-17-2010, 10:02 AM
Cobra Make, Engine: 408w 500 h.p. 550 ft.lbs
A little known fact is that shifter will also increase your fuel mileage by 6-7MPG.
Craig
Old 05-17-2010, 11:37 AM
Hmm.. I googled that and could not find any supporting facts..
Old 05-17-2010, 03:36 PM
snakebitekit's Avatar
Cobra Make, Engine: ERA FIA #2119
Try looking on SNOPES
Old 05-19-2010, 04:54 AM
Cobra Make, Engine: Classic Roadsters 351 Windsor 405 HP
I have a Tremec 5 speed, I cut the shifter down and re-drilled two holes to make it fit. It's shifts quick. But. when it's cold outside the shift boot gets sfiff and makes it pop out of gear so I have to hold it in gear for a few miles.
Display Modes
