04-11-2011, 11:19 AM
Wi
Sidepipe fix for the restrictive side pipes
I was re-reading "Pete's Cobra Project" and noticed that he mentioned in his build that there was a fix for the restrictive side pipes here on the forum.
Mentioned here.
I did a quick search and did not find anything...
What is the fix (and I am hoping that it's not buy a new set of side pipes and that's if they are available anymore.  )
Thanks...
04-11-2011, 11:21 AM
New pipes from Buckshot fabrication in North Carolina, they make pipes for big blocks, no restrictions.
PRIDEnJOY
04-11-2011, 11:54 AM
Wi
No surgery on the pipes then???
I was hoping you would be able to make a cut on each end and eliminate the plate that connects to the 1-1/4 pipe and then patch it up inconspicuously…
When I got my kit, the pipes where nickel coated already… I am keeping them until I finish my car, then I guess I will update them at a future date.
04-11-2011, 12:42 PM
Search Classic Chambered on here and you'll see what a lot of us have been using.
There's 100+ horsepower waiting for you to unleash it for cheap money.
04-11-2011, 01:09 PM
Tx
Cobra Make, Engine: Classic Roadster, 408 LSX
Plenty of folks have cut out the mufflers and had new, less restrictive, ones welded in. Obviously they have to be recoated though.
-Greg
I've spent most of my money on cars and women. The rest I wasted.
04-11-2011, 01:49 PM
Wi
Sounds like I am going to have to have my mufflers re-coated.
Shame because the nickle is so nice looking.
04-11-2011, 05:29 PM
Performance Engineering is upgrading mine to a 3 inch muffler and ceramic coating. $1200.
04-11-2011, 08:07 PM
Wisconsin- The CR mufflers have that restriction at both ends of the muffler. The 1 1/4" tubes are offset inside there. The only fix is new Muffs sorry. I went with Classic Chambered as Mick mentioned. Cut out the old, welded in the new and had them recoated. Yes I'm happy with the upgrade. BTW I went with the 30"x2 1/2" packed with the louvers open to the rear. Good luck!
04-12-2011, 10:09 PM
Wi
Well, before I start replacing stuff I already have, I have to get the car going...
Still have a ways... I will be keeping Classic Chambered in mind for the first upgrade once the car is complete.
