Old 02-15-2011, 07:29 PM
Default Needed Side Pipe Flange spacer
I need to space one of my side pipes out by .75 inches. The flange between the side pipe and the collector is the perfect place to put in a spacer. The flanges are 5.00 inches square and the tubing inside diameters are 1.875. The four tubes are spaced 2.125 center to center. Does anybody know where I can buy these flanges and gaskets? Thanks
Old 02-15-2011, 08:05 PM
mickmate's Avatar
I have made them before if you can't find them.
mickmate
http://www.actoncustom.com/
Old 02-15-2011, 08:36 PM
I can send you a CAD file of the gaskets that I made and you can have it made locally to you if you want.
Remember, spacing it will not only move it out but down also unless you have it machined at a slight angle.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
Old 02-15-2011, 08:46 PM
Double Venom's Avatar
HPCOBRA,
Just checking...is this a new build? are you sure; A. the headers are on the right side?
B: you have used the correct motor mounts and have them in correctly?
This problem making up or shortening the exhaust route a full 3/4" is usually a sign of one of the above?
Old 02-16-2011, 01:18 PM
I am doing a rebuild. The original builder was less then a craftsman! I can not explain why the one side is cut and welded short. A .75 spacer places the side pipe exactly where it should be. Right now the pipe is a little high and very close to the lower front fender. I loosened up everything and moved it out .75 inches. It looks like it belongs there
Old 02-16-2011, 04:16 PM
Hmmm,
OK, so it is a re-build. 'DV' (DoubleVenom Cobra) used a 3/4" spacer plate between the headers and the side pipes. The spacer plate was used to hold a "Bung" for an 02 sensor! ??
Second thought, your spacer plate does NOT need to have a "Four' Hole Pattern in it! Just a solid 3/4" plate cut/milled out to the outside size of the headers/collector.
Didn't know if that configuration or lack of it would allow the pipes to work properly???
A lot of professional testing, Three different Dyno's and the only thing for what ever reason was an in increase of 3 (Three) RWHP and the sound was awesome-for a Viper Engine!
Food for thought, hey? Both sides 'should be done the same'!
Old 02-18-2011, 08:33 AM
Cobra Make, Engine: shellvalley 428 ford
HPCOBRA: Check here. I believe this is what you want.
Good luck, Byron W
http://craigscobras.com/parts/spacer/
Old 05-20-2011, 01:38 PM
Cobra Make, Engine: SOLD Excalibur, '94-'95 5.0 EFI, Edelbrock heads, E303 cam, 1.7RR, Cobra intake, 24lb injectors, 93 cobra ECU, 65mm TB, hi flow cats.
Default Gaskets for collector and spacer
Where can I buy gaskets to fit these collectors or spacers?
Thanks,
Mike
Old 05-20-2011, 04:39 PM
Mike,
Hi-Heat orange/black permatex works great. No gaskets needed.
DV
