January 2026
4 5 6 7 8 9 10
11 12 13 14 15 16 17
18 19 20 21 22 23 24
25 26 27 28 29 30 31
Old 07-10-2011, 08:33 AM
Cobra Make, Engine: Classic Roadsters ltd,
Default Starter problem?
Hi, Had a problem the other day when I sarted the car. The starter kept running after the engine was running. I then tried to shut the car down and it would keep on running. I fiinally got it to shut off. Not sure why this would happen? Any Ideas out there?
Thanks
Bob
Old 07-10-2011, 08:47 AM
mreid's Avatar
Cobra Make, Engine: Kirkham 289 FIA #690, FRPP 427 Boss engine
Do you have a mini starter or standard? If mini, how is it wired (firewall solenoid in addition to starter mounted)?
Starter run on can be caused by a sticky solenoid, dual solenoid conflict, bad starter, bad ignition switch, or wiring issues. Post more info on your set up. Also, did the engine keep running because it was being turned by the starter or was it actually running? If it was actually running and you had turned it off, this is almost definitely the ignition switch.
RCR GT40 SOLD to Fast 5
Kirkham #690 289 FIA
Old 07-10-2011, 09:23 AM
Default Sarter problem
The engine was running. But the starter was also running. How hard is it to change the ignition switch for a GM steering colunm?
Old 07-11-2011, 04:31 AM
Double Venom's Avatar
Piper,
Starting with the basics, it is most likely the ignition switch. You will need to pull the steering wheel off, right down to the "turn signal switch". Look through the switch on the right side, you will see a fairly large screw under the switch. (You can see it through a hole in the switch.) Take this screw out and the ignition switch will fall out in your hands. A new switch can be had at almost any auto parts store. Reverse installation, replace the screw, steering wheel etc.
Done and ready to go
DV
