Old 06-11-2012, 12:33 PM
Default Is there a gas sending unit that works on the cobra tank that uses AN fitting?
I am going to run a fuel injected 5.0 and need to do the plumming.
Is the sending unit a universal type of sending unit?
Otherwise does anyone have a idea how to make the transition from the sending unit to the -6AN fuel line?
Old 06-11-2012, 01:31 PM
Rick Parker's Avatar
OEM's utilize clips in their fuel lines for quick disconnect, they requir specialized toold for disassembly. Ford uses them on the 5.0 fuel rails and other place for sure. If you want to attempt to modify the pump assembly it will require welding a male AN fitting to the pump assembly.
Old 06-11-2012, 02:17 PM
Rick, I have the special quick disconnects for the fuel rails.. This is concerning using a Classic Roadsters gas tank and utilizing AN fittings. Thanks
Old 06-19-2012, 06:52 PM
MaSnaka's Avatar
Make sure you ground your gas tank. Or your sending unit won't work.
Old 06-20-2012, 06:59 AM
bobcowan's Avatar
Not a big deal. There are a couple of companies that make a fitting especially for this application. One end connects like the stock Ford fitting. And the other end has an AN male fitting. Call Mike Forte, and he'll hook you right up.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
