Old 04-10-2013, 09:14 AM
Default Wiper install instructions
Hi all.recently purchased a 68 Cobra made in 1999 by Classic roadster in Fargo ND . Just wondered if anyone had some wiper install instructions and or pics they could share. Purchased the kit from Finishline. I have a call in with them also. Thank you
Old 04-10-2013, 01:46 PM
Look at the motor, you will see one of the wires is blue. Disconnect it from the plug and take it to ground. That's it, it should work fine.
Old 04-10-2013, 03:56 PM
Do you have the manual? The "limited" instructions are there with some pictures.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
Old 04-12-2013, 04:26 AM
Double Venom's Avatar
If you don't have the manual, let us know. I might be able to dig up the instructions. As crazy as it sounds 'JEwalt' is right on! remove, cut the original wire (blue) and take it to ground. The mounting case works just fine.
DV
Old 04-14-2013, 04:29 PM
Thanks all. I appreciate the input. Finshline emailed them to me. Thanks
Old 04-15-2013, 04:57 AM
Ferguson,
I Think (?) what finishline is sending you is a instruction sheet and/or a wiring schematic for a basic install. It is not the same as CR's install by any means, nor is their wiring schematic compatible with CR's. Can be mighty confusing for the un-informed. Just thought you might want to know.........
DV
Old 06-08-2013, 12:57 PM
Thanks everyone for the input. Install went well,but time consuming. Used steel 5/16 fuel line between the pivots. Tried using the plastic line as was recommended,but it couldn't contain the drive cable.
Display Modes
