Old 09-03-2014, 08:24 AM
Smile starting a warm 351 , crank won't start
i drive it 3-4 miles shut it off & go to start it 10 min. later just crank's wont fire , if i let it sit for 20 min. or so it starts & i can shut it off & re starts . 3 times this wk. a bit scary ! any idea ? it is a 351 W with mallory dist. & jacobs ing.
Old 09-03-2014, 11:14 AM
*13*'s Avatar
Could be the starter getting too hot. When it cools a bit, it spins. Heard of this a number of times. Often when the exhaust is too close to the starter. If this is the case, it may be that the starter has air passing over it when driving, keeping it a bit cooler.
ERA FIA 2088
Old 09-03-2014, 11:44 AM
Cobra Make, Engine: Backdraft 1048
If it cranks it's not a starter issue maybe it's the coil so I would check for spark when it occurs.
Gary
Backdraft 1048
Old 09-03-2014, 11:53 AM
Rick Parker's Avatar
Look at the field coil/light emitting diode module inside the distributor.
Most likely the above, electronics do not like heat.
Rick
Old 09-03-2014, 03:22 PM
it crank's no spark !
Old 09-03-2014, 05:28 PM
Dwight's Avatar
Smile
no spark, I would look at the coil.
could be fuel filter. Maybe fuel pump.
Old 09-26-2014, 08:20 PM
Lightingrod's Avatar
Cobra Make, Engine: Classic 427, I purchased it May 2005, the kit was bought in 1991. I'm not sure when it was completed! Installed GMPP Connect & Cruise 376/525 with T-56 S/M 3.55 gears about 2 years ago! 1/4 miles is with old setup!
Mallory Dist for sure unless your spark box is to near heat! The GMPP 572/620 I had ate MSD modules like candy! When they went bad it WOULD NOT start when hot, let it cool and it would fire right up. Got rid of the distributor module and put an old 6AL in the glove box and never had another problem!
Al
I want to do right, Just not right NOW!
Old 09-26-2014, 10:39 PM
I had this problem as well when I first got my Cobra on the road. It turned out to be heat soak boiling the fuel in the carb and lines and likely creating vapor lock. The solution was to add a 1/4" phenolic spacer between the carb and intake, and also to insulate the fuel lines with fiberglass/reflective wrap from McMaster-Carr. Solved the problem.
Old 09-26-2014, 11:21 PM
Simple test fuel or spark, pour a cap of fuel in the carb! Or move the throttle and see if it's getting a shot of fuel, if it's getting fuel and don't start it's spark!
Al
Old 09-27-2014, 01:12 AM
RedSnake351's Avatar
Cobra Make, Engine: ACE, 351W, 3550 Tremec, Raging(?) Red W/ White Stripe.
In his post #5, he already said, "cranks, no spark"!!!
Ralph
SPEED WAS HIGH - WEATHER WAS NOT - TIRES WERE WET - X MARKS THE SPOT
Burma Shave
Old 09-27-2014, 04:55 AM
^^Yes he did!^^
I guess I was having a "senior moment" on that second post?
DISTRIBUTOR MODULE!
Al
Old 09-27-2014, 02:29 PM
Cobra Make, Engine: Classic427 351w
Possibly carb flooding? Try holding the gas pedal to the floor while cranking. Old school start up on carbureted engines.
