Old 06-24-2014, 03:26 PM
Default Driveline angle - Should the engine be slightly tilted towards the rear?
I am measuring up the distance needed for the driveshaft that I need built and looking that the engine/tranny, I notice that it's tilted slightly backwards.
Should the engine tranny be straight horizontal to the ground or is it supposed to be tilted slight towards the back of the car?
Old 06-24-2014, 03:50 PM
RET_COP's Avatar
I believe your asking is the tail shaft (transmission/Engine) angle downhill from front to rear. The build of the car would dictate this.
What is important is the relationship between the tail shaft and the pinion CL. It should be close to parallel to a 1 to 2 degree down angle on the pinion on a straight rear. Different setups require different degrees of pinion angle.
Lou
Old 06-24-2014, 04:10 PM
Double Venom's Avatar
Pinion angle - "NEVER" upward.
DV
legenmetals's Avatar
Google pinion angle. I think you will find plenty of info.
