Old 07-23-2015, 05:32 PM
Cobra Make, Engine: 1992 Classic Roadsters, 427 Dart Stroker, Tremec 5spd, 8.8 positrac differential
Unhappy Pulling dash on CR
Newbie here, I just bought a 1992 classics roadster and a couple of the toggle switch's in the dash are broken. access is very very limited, I can remove the switch from the back of the dash thru the heater vent access after I pull it, but there is not enough wiring to pull the switch's thru the access hole. I also need to replace the cassette radio with a newer CD version. What is the best way to access these components. Is pulling the dash out several inches feasible?
