Old 11-01-2015, 09:32 AM
Cobra Make, Engine: Classic Roadsters Chevy 350
Default Help needed: air filter
So yesterday I went to find a new air filter for my CR with a 350 Chevy. Apparently I have the unicorn of air filters, it is an oval filter and measures 12" long and 9.5" wide with overall height of 2.5" (2" being actual filter element). The only 12" oval filters I can find after an extensive search online are barely over 8" wide. The current filter has no brand name just says Model-351 (no help so far on my online escapade). The air cleaner has a top plate that says Cobra, but I have no idea who made it as it is much shorter than a true Cobra cleaner assembly. I'm almost to the point of replacing the entire air cleaner, although I'd prefer to spend ~$25 on a filter instead of $100-200 for an entire assembly. Any help would be great!
Old 11-01-2015, 11:17 AM
G_Edmonds's Avatar
Cobra Make, Engine: Classic Roadster, 408 LSX
If you use a cotton gauze type filter(K&N), a round filter is used. Just squeeze in the sides. A little quick figuring comes to just a hair over 11 inches diameter. it would be handy if an 11" would work because there are multiple heights available.
-Greg
I've spent most of my money on cars and women. The rest I wasted.
Old 11-01-2015, 07:39 PM
For now I put an edelbrock 10" round filter assembly on it, I think I may have to experiment with squeezing some round filters to fit. Joyful times!
Old 11-02-2015, 02:22 PM
-Greg
I think I will try to find an 11" and see if I can make it an oval. Would like to have the "Cobra" air cleaner assembly on there when I pop the hood instead of a plain Edelbrock cover...
Old 01-08-2016, 04:31 PM
Cobra Make, Engine: 1992 Classic Roadsters, 427 Dart Stroker, Tremec 5spd, 8.8 positrac differential
Default Correct airfilter element
Sounds like you have the same "cobra" filter housing I do, and went thru the same search for an element. Thanks to the local NAPA sales guy I foud one that is a pretty good fit. Its a NAPA part 2071 for a 71/72 Pinto. It measures 11.030" Dia. 8.925" ID and 2.300" tall. Just squeeze til its oval and you're good to go. Hope that helps you
Old 02-29-2016, 09:56 AM
Just ordered one through my local NAPA, thanks for the heads up!
Old 03-06-2016, 06:24 PM
IT WORKED! Thanks for the info 331!
