Like Tree2Likes
  • 2 Post By HighPlainsDrifter
Old 08-24-2018, 08:36 AM
HighPlainsDrifter's Avatar
Smile Making progress
After 3 months of sorting out unfinished kit I have a few items taken care of;
-made passenger door hinge and mounted, latched both doors( no small feat as had to be extra careful because car is painted)
.-mounted gas tank and lemans filler.
-modified mustang pedals and mounted them.
-modified mustang power brake system, installed new master cylinder and brake lines. (had to fix 7 bad items in brake system)
-made brackets and installed steering column
.will move on to the dash next.
.Perry
G_Edmonds and Alfa02 like this.
F5 cobra Mark 4 roadster, **SOLD** Ruby Wine Red with pearl,
dual 2" roll bars, warmed up 302, Edelbrock AVS carb and heads, E Street aluminum Heads, Comp cam and roller rockers, AOD, 4.10 Eaton Posi, Power Baer/disc brakes, block hugger headers, 2 1/2" under car exhaust, F500 18" black spoke wheels.
Old 08-26-2018, 05:22 PM
Looks like you have the door lined up about perfect...
I am happy you got the car and good luck with the rest of the build!
Old 08-26-2018, 05:48 PM
Alfa02's Avatar
Gold Star Contributor
Ditto, to Wisconsin Snake's Comment. If you need anything else from us guy's, we're here for you, Cheers Tom.
Old 08-30-2018, 11:30 AM
Default Hood done
Hi,
Had to cut out hood scoop air intake and touch up paint. Also made hood hinges, mounted it and installed latches. I like the size of the scoop. Also installed wiper motor and wiper boxes.
Perry
Old 08-31-2018, 04:31 AM
Chicagowil's Avatar
Its looking great! I like the way the color highlights the curves.
Every time I think I will finally will have time to get going on mine to finish, something else sucks up the space/time.
Did you change the operation/location of the clutch & brake pedals?
Old 08-31-2018, 08:33 AM
Default pedals
Hi,
I used 1990 mustang pedals and shortened the clutch side 3/4" and moved the pedals left that much to clear the steering column. The brake was in the same spot. Made gas pedal bracket also.
Perry
Old 09-02-2018, 05:42 AM
Chicagowil's Avatar
That all looks more normal than mine. My clutch pedal is very high off the floor. And it would be impossible to heal/toe.
