| S |
1 |
| 2 |
5 |
8 |
| 9 |
12 |
15 |
| 16 |
19 |
22 |
| 23 |
26 |
29 |
| 30 |
2Likes
2
Post By HighPlainsDrifter
08-24-2018, 09:36 AM
BC
Cobra Make, Engine: F5 Roadster
Making progress
After 3 months of sorting out unfinished kit I have a few items taken care of;
-made passenger door hinge and mounted, latched both doors( no small feat as had to be extra careful because car is painted)
.-mounted gas tank and lemans filler.
-modified mustang pedals and mounted them.
-modified mustang power brake system, installed new master cylinder and brake lines. (had to fix 7 bad items in brake system)
-made brackets and installed steering column
.will move on to the dash next.
.Perry
F5 cobra Mark 4 roadster, **SOLD** Ruby Wine Red with pearl,
dual 2" roll bars, warmed up 302, Edelbrock AVS carb and heads, E Street aluminum Heads, Comp cam and roller rockers, AOD, 4.10 Eaton Posi, Power Baer/disc brakes, block hugger headers, 2 1/2" under car exhaust, F500 18" black spoke wheels.
08-26-2018, 06:22 PM
Wi
Cobra Make, Engine: Classic Roadsters, 95 EFI 5.0
Looks like you have the door lined up about perfect...
I am happy you got the car and good luck with the rest of the build!
08-26-2018, 06:48 PM
WA
Ditto, to Wisconsin Snake's Comment. If you need anything else from us guy's, we're here for you, Cheers Tom.
08-30-2018, 12:30 PM
BC
Hood done
Hi,
Had to cut out hood scoop air intake and touch up paint. Also made hood hinges, mounted it and installed latches. I like the size of the scoop. Also installed wiper motor and wiper boxes.
Perry
08-31-2018, 05:31 AM
WI
Its looking great! I like the way the color highlights the curves.
Every time I think I will finally will have time to get going on mine to finish, something else sucks up the space/time.
Did you change the operation/location of the clutch & brake pedals?
08-31-2018, 09:33 AM
BC
pedals
Hi,
I used 1990 mustang pedals and shortened the clutch side 3/4" and moved the pedals left that much to clear the steering column. The brake was in the same spot. Made gas pedal bracket also.
Perry
09-02-2018, 06:42 AM
WI
That all looks more normal than mine. My clutch pedal is very high off the floor. And it would be impossible to heal/toe.
