Old 04-08-2020, 12:19 PM
Cobra Make, Engine: 302. 1992 build
Default Rear end
Hey guys Bulldog here hope everyone is staying safe with this virus going around.i have a question about my 8.8 locker rear end, have everything ready to go back together but having a time getting the opinion bearing pre load right.Ford says opinion nut needs to be140 ft.lbs. of torque and then set pre load at 18 to 23 inch pounds .that is a lot of torque having trouble getting it there.anyone had experience with this rebuild?
Old 04-08-2020, 04:38 PM
Tom Wells's Avatar
Bulldog,
DuckDuckGo is your friend!
Here's one video I found that may help you: https://www.youtube.com/watch?v=8APYO2sZyJU
When I did this, I had the advantage of a rather large bench vise to hold my flange tool, so I could pull against it with the torque wrench. Also, I think the preload is more important than the torque spec, so I'd make sure not to overtorque the thing!
Hope this helps,
Tom
Old 04-08-2020, 07:12 PM
Default Rearend
Thanks Mr.Wells,was think the same thingabout pre load.will visit that site. Bulldog
Old 04-09-2020, 06:20 AM
Dwight's Avatar
Neutral
Smile
We did one in the car with the tires holding the gears and two of us pulling with a medium length torque wrench. There has to be a better way.
Old 04-09-2020, 07:53 AM
Tom Wells's Avatar
Dwight,
If you can find or fabricate the flange holding tool - shouldn't be prohibitive because basically it's a flat bar with a couple of holes in it - it can rest against the floor of the car underneath. That way the car can be lifted up a bit to make it easier to use the torque wrench.
Tom
Old 04-13-2020, 12:16 PM
Default Rear end
Tom, made a tool for that will see how it works thanks again. Bulldog
Old 04-14-2020, 07:49 AM
HighPlainsDrifter's Avatar
Cobra Make, Engine: F5 Roadster
Exclamation locker rear
Hi,
The locker rear will have to be driven differently. When you are on the gas the car will want to go straight even if you are turning the wheel for a corner! Just remember to get off the gas to turn.
Perry.
F5 cobra Mark 4 roadster, **SOLD** Ruby Wine Red with pearl,
dual 2" roll bars, warmed up 302, Edelbrock AVS carb and heads, E Street aluminum Heads, Comp cam and roller rockers, AOD, 4.10 Eaton Posi, Power Baer/disc brakes, block hugger headers, 2 1/2" under car exhaust, F500 18" black spoke wheels.
