Old 05-07-2020, 10:53 AM
Chicagowil's Avatar
Default CR Side pipes do not align
I was test fitting my side pipes and I discovered the Driver's side rear mount extends about 1" too far for the mount hole to align.
Has anyone else had this issue?
Old 05-08-2020, 09:55 AM
MaSnaka's Avatar
That sucks! Can you relocate the mounting bracket on the pipe or create an offset bracket to connect?? To answer your question though...no I did not have the misalignment. BB FE.
John
Old 05-11-2020, 01:30 PM
Cobra Make, Engine: Classic Roadsters, 95 EFI 5.0
I ran into the same issue but on my passenger side.
I have not resolved it yet, I was thinking of elongating the hole and using a large washer/ rubber pad to make up the distance or cutting the bracket and welding where it would line up.
P.S. I sent a PM.
Old 11-07-2020, 07:59 AM
Chicagowil's Avatar
It turns out that I had switched the the motor mounts to the wrong sides when I replaced the original with convertible mounts to lower the mounts. Slightly lifted the motor, switched them side to side and the pipes lined up! But now I have added problem of the supercharger snout hits the hood!
Will keep everyone advised. Have been busy with the house
