Like Tree4Likes
  • 1 Post By BigGuy
  • 2 Post By DanEC
  • 1 Post By bobcowan
Old 10-02-2020, 06:05 AM
G_Edmonds's Avatar
Cobra Make, Engine: Classic Roadster, 408 LSX
Default Side mount mirror screw
I have ray dot mirrors mounted to the side of the windshield with the Finishline side mount brackets. After 11 years one of the screws is stripping and will not stay put. What should I do? I’ve considered trying a slightly larger screw but I don’t want to mess things up worse. Also considered just putting it in with some Loctite. What do you guys think?
-Greg
I've spent most of my money on cars and women. The rest I wasted.
Old 10-02-2020, 11:21 PM
BigGuy's Avatar
Cobra Make, Engine: CSX4xxx, Alum. Shelby 427 w/ Webers,
Do not oversize .... go with loctite or little clear nail polish ( or what ever you like color-wise)
if you oversize by forcing a larger screw in there you’ll have issues. Unless you tap/thread it to the size your going to.
My .02
G_Edmonds likes this.
Jon
Old 10-03-2020, 06:40 AM
DanEC's Avatar
You could try some blue loctite. I would not use red. There is an orange loctite that has most of the properties of red but does not require high heat for removal.
BigGuy and G_Edmonds like this.
ERA 782 Running
Old 10-03-2020, 07:56 AM
bobcowan's Avatar
Get a Permatex 81668 Stripped Thread Repair Kit. It's perfect for these small jobs.
https://www.amazon.com/Permatex-8166.../dp/B000AL4WAS
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 10-08-2020, 09:59 AM
MGM MGM is offline
Default Side mirror bolts
Anyone know the best way to remove the bolts? My mirror was broken so I ordered a replacement from Finishline. Not quite the same though. I can get at one of the bolts, but the other one looks to be a challenge. I put it on the back burner as I rebuilt the engine. Anyone have any advice? Thanks!!
Old 02-14-2021, 04:43 PM
Cobra Make, Engine: SPF832, 466cid
Originally Posted by winkytill View Post
If it's a shared wall with your neighbor or common area its most likely double drywall. U don't have to find a stud. 50lbs is not that much. Toggle bolts will easily hold the weight.
Ok Bob Vila
Old 02-14-2021, 06:07 PM
Winky the Bot running loose. If we had a moderator...
Old 02-14-2021, 11:59 PM
saki302's Avatar
With these fiberglass bodies, I wonder if some mixed resin, carefully dripped into the hole with a toothpick, would allow the screw (Assuming self-tapping) to cut new threadsand work like new?
I've never tried it yet, but the idea is sound
-Dave
