Old 03-22-2021, 08:01 AM
Sycraft's Avatar
Cobra Make, Engine: ford 302
Default What Column is this
Need to order a hub for a Nardi wheel I have from my father. I did not know what column this is to order correct hub. Anyone have the info?
Old 03-22-2021, 10:10 AM
Off hand, I would say it is an aftermarket "Chevy" style universal, like the Helix brand. The controls are different from most stock columns. I bet if you look underneath the dash you will see the giant dumb Chevy big flat connector. The kit on it looks like a generic Grant unit.
https://www.summitracing.com/parts/hli-10020
Old 03-22-2021, 10:31 AM
joyridin''s Avatar
It looks like an early Chevette style column to me. It could easily be an aftermarket column like stated above also.
Old 03-22-2021, 01:30 PM
bobcowan's Avatar
It is a stock Chevette column from the early 80's. I can't remember the exact years. If you were lucky, you could find one with the tilt feature.
The hub is standard aftermarket stuff, with a provision for the horn button. I think they had 3 bolts to hold the steering wheel to the hub adapter.
To know the exact fit, you'll have to pull the hub and measure the shaft for diameter and spline count.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
Old 03-22-2021, 01:50 PM
Sycraft's Avatar
This has the tilt feature.. thanks all
Old 03-22-2021, 04:44 PM
G_Edmonds's Avatar
Cobra Make, Engine: Classic Roadster, 408 LSX
My ididit looks just like that, including the billet look knobs.
I've spent most of my money on cars and women. The rest I wasted.
Old 03-22-2021, 06:11 PM
sunman's Avatar
My Chevette tilt had a key on right side. It was ground off, body worked and I am going to use a remote start/alarm unit.
Old 03-22-2021, 07:16 PM
Sycraft's Avatar
This hub may work, its for a Chevy spline and Nardi Wheel, we will see...
Old 03-22-2021, 10:43 PM
Chevettes had the key as stated, also the housing cover is squared off on the left side. Not a chance iin hell it's a stock Chevette column.
1979: https://cdn-0.barnfinds.com/wp-conte...chevette_e.jpg
https://s.aolcdn.com/dims-global/dim...-photo-b-1.jpg
Old 03-22-2021, 10:49 PM
Chevette installed in a CRii, zoom in a bit on the pic, you will see plainly that is not it.
http://smclassiccars.com/uploads/pos...adsters-11.JPG
Old 03-23-2021, 04:25 AM
joyridin''s Avatar
I forgot about the key. I ground my key off also. Definitely not a Chevette.
Old 03-23-2021, 07:12 AM
Chicagowil's Avatar
I have the Chevette (translated- Shove-it America if you remember Chevy's commercials) in my CR1. It does have the tilt and key
Thom
Old 03-24-2021, 04:36 PM
MaSnaka's Avatar
If memory serves me from the Don Scott days it is the Chevette steering column. My CR didn't have that one so I couldn't tell you what it looks like. Is there a part number you can google??
