Like Tree2Likes
  • 2 Post By Grubby
Old 04-24-2021, 04:21 PM
Cobra Make, Engine: 302. 1992 build
Default Speedo gear
Hey guys Bulldog here haven't posted for a while. The Speedo gear in the t 5 tyranny keeps wiping out the teeth on the gear . the gear that. Clips to the cable just started have replaced a couple . Has anyone had this problem?
Old 04-24-2021, 04:50 PM
Dwight's Avatar
Smile
how many teeth on the gear?
Old 04-24-2021, 04:56 PM
Grubby's Avatar
Cobra Make, Engine: ERA 838
Fords have both LH and RH driven gears. Putting the wrong one in will cause it to get wiped out.
twobjshelbys and 74proii like this.
Old 04-24-2021, 06:33 PM
https://performanceparts.ford.com/do...UsageChart.pdf
Old 04-25-2021, 04:30 AM
Cobra Make, Engine: Ford 331 V8
Call Speedometer Service Co. Milwaukee, WI. 414 463-6660. Super fair people and very knowledge concerning anything to do with T-5 speedo gears etc.
Old 04-25-2021, 09:03 PM
Cobra Make, Engine: Classic Roadsters Chevy 350
Depending what gauges you are running, I found a GPS speedo that matched by Autometer set when I frankensteined my transmission together. Eliminated need for speedo gear and if I ever change rear gear ratios then I don't have to worry about changing the speedo gear. Food for thought.
Old 04-26-2021, 06:48 AM
Default Speed ogear
Thanks guys for info i will see what I can come up with. Gear is 23 teeth
