Old 11-04-2021, 12:30 PM
Cobra Make, Engine: 91 CLassic Roadster 460ci
Default Need Verification of Rollbar Mtg Holes
I am ready to cut the holes for mtg the supplied Classic Roadster Rollbar. I know it is classified as cosmetic but I like the look of it. I do Not have the original supplied template or location measurements. I positioned it as I think it should be . I appreciate if someone who has one mounted could verify with a few tape measure dimensions. My locations are as such:
- From the edge of the cockpit the two from legs is 2.5” from the rolled edge
- From the centerline of the car the first front leg is 7” and the second 19”
- From the rolled edge of the cockpit the third leg is 9.5” and 16” from the centerline of the car
I really would appreciate if anybody with the same Rollbar could check yours with a tape measure to see if my dimensions look correct. It would be a real pain to repair the holes if I was wrong.
Thanks for any help
Old 11-04-2021, 12:48 PM
I am a little concerned because the roll bar does not line up with the center of the seat. The dimensions from the centerline were passed on to me on a hand written piece of paper that came with car. I can not verify them. I am concerned because some time ago I saw a pic and if memory serves me well it looked like the outer most leg was in line with the rear suspension adjustment bolt head. My measurements would put the leg approximately.75 inches off the centerline of the adjustment bolt. The Rollbar leg is moved .75” towards the passenger side.
