Like Tree2Likes
  • 1 Post By cwg427
  • 1 Post By KarlzEE Bebout
Old 11-06-2021, 08:46 AM
Default Parking brake handle and cable?
What parking brake handle and cable have others used, or recommend?
I have a t5 from a 91 mustang and the rear is an 8.8 that I'm planning on adding disc brakes from an SN95. I could go the donor route and use one from a mustang, but was thinking about a Lokar or equivalent. The more factory route would be to have a handle mounted between the pass seat and trans tunnel. Is that possible on the CRII? I was looking at these:
https://www.summitracing.com/parts/l...7011?rrec=true
Or if I want to stay with the handle mounted on the center of the tunnel, this:
https://www.summitracing.com/parts/lok-ehb-7000f
This is the cable I was planning on using:
https://www.summitracing.com/parts/lok-ec80tu
Is there a certain year of mustang or donor route that doesn't look have all the molded plastic? I haven't been out to look at the 90's mustangs I have because they're in storage but as far as I can remember, they look like their from the 80's/90's
I'd appreciate any advice, part suggestions, pictures, ideas
Old 11-06-2021, 09:59 AM
Cobra Make, Engine: 91 CLassic Roadster 460ci
Mine came with the original kit. It is out of a 71-73 pinto. A couple years ago I found a NOS plastic enclosure for it. Works with my 90’s Corvette brakes.
Old 11-06-2021, 07:33 PM
Cobra Make, Engine: Street beast 1966 cobra replica
Locar lever and cables.
Roylerumble likes this.
Old 11-06-2021, 09:44 PM
Don't make the mistake of mounting the lever well forward in the passenger foot box side of the tunnel. My FFR friends with that set up get all pissy when they have to unlock their harness to be able to reach the lever to release the parking brake.
Old 11-10-2021, 08:02 PM
Kevin. I used that lokar handle and cable set. The only thing you have to do is somewhat fabricate the mount. The lokar is designed to be mounted from below. That will put it well below the tunnel cover and that won’t work. I turned the mount “tabs” over and changed it a bit to mount on top. It works great like that and hugs the tunnel so it’s not in the way. Won’t let me add pics. I’ll e mail them to you.
Jeff
Old 11-10-2021, 08:39 PM
Cobra Make, Engine: MidStates, 351C, 4spd, 9"
Send a message via AIM to krausewich
Lokar.. Best to mount it on the tunnel. You won't be reaching the passenger floor in an emergency!!
"It's not about getting from point A to point B. It is the point"
-J. James
M. Krause
1.508.944.3368
Old 11-11-2021, 07:29 AM
Jeff
Got the pics Jeff! thanks for the email. Lokar and cables ordered!
