Like Tree3Likes
Old 01-13-2023, 05:33 AM
Default Door latches, just throwing this out there
Classic Roadster door latches.... Why did they, probably the only ones, build a car with the door latch in the jamb and the pin in the door, and not the other way around? I'm building my car, don't have the doors and body in the shop at the moment and haven't put a lot of thought into it yet, so I'm just throwing this out there to see other thoughts, but has anyone looked into modifying it to reverse it so the latch is in the door, and the pin in the jamb, like every other build out there. Having the latches in the wheel well where dust and debris can be a problem, the hoakey bicycle cable lever (I almost threw them out when going through the parts boxes thinking they got thrown in there when someone was cleaning out the garage), just seems goofy. A nice set of latches from any of the parts dealers is only a few hundred bucks.
Anyone thought about modifying it the door latch system?
Old 01-13-2023, 05:42 AM
Grubby's Avatar
Cobra Make, Engine: ERA 838
I agree. You should be able to fit Cobra OEM style latches without too much trouble.
It would look more original.
Old 01-13-2023, 06:52 AM
Chicagowil's Avatar
A standard Cobra door latch will not install easily do too the side impact steel beam in the door. I plan on using a electric solenoid door latch release.
https://www.jegs.com/i/Mr-Gasket/720/6188/10002/-1
I have not tried to fit them yet, but my CR1 came with rear inner fender liners. That should protect both the latch and the body from road debris.
My car goes (finally) to the body shop next week. He has a lift and we will test fit the liners at that time. I figure I will cut an access hole and add a removable cover for access.
Old 01-13-2023, 07:35 AM
Cobra Make, Engine: Classic Roadsters, Ford coyote Gen1
My CRII is modified that way with the latch inside the door.
Mark
Old 01-13-2023, 07:56 AM
Cobra Make, Engine: built the molds and body composite construction
Suggest you look at rockyhinge.com, I like the Bear claw system but they should have something that meets your needs, be aware that they as like many suppliers are having part supplier problems, so check that they have it in stock.
Bill K
Old 01-13-2023, 06:28 PM
would be awesome to see your set up
Old 01-13-2023, 07:22 PM
Chigagowill, need to see your progress.
man this site blows for uploading pictures, everything fails to upload.
You don't think a latch like this would work? they are on the superperformace cobras
https://bringatrailer.com/listing/su...iii-cobra-5-2/
Old 01-14-2023, 04:36 AM
Picture disappeared!
Mark
Old 01-14-2023, 04:38 AM
Mark
Old 01-14-2023, 04:40 AM
Mark
Old 01-14-2023, 04:57 AM
You have to find the picture of the release knob and keep clicking the left arrow till this pic comes up.
https://www.streetrodhq.com/dept/Door/cat/Latches.html
Mark
Old 01-14-2023, 07:44 AM
Ron61's Avatar
When I had my Classic Roadster I had the latches in the door like most of them do. I didn't care for the latch in the jamb setup.
Ron 61
Ronnie Widener
View my Miscellaneous Gallery
Old 01-14-2023, 07:55 AM
Angry
Bear Claw seem to have this on their web page, and I saw the set up on another site that showed it assembled inside the door. I'll see if I can find it again; but as stated it's a pain in the MoFo rear to post pics or links on here.
we can put men on the moon and mars, robots do surgery, cars drive themselves, but try to post a pic on clubcobra.com, nope
markantioch likes this.
Old 01-14-2023, 08:23 AM
It was a solid 45min relearning curve on how to post again. And I guarantee it'll be the same next time I post something in the future.
All 3 of the first posts had a picture with them, none are showing now!??!
Mark
Old 01-14-2023, 08:46 AM
Trying this attachment one more time.
One will have to download the images and rotate them right side up. Don't know why this site messes up a simple download.
Mark
another idea, wonder if it would work
https://www.ffcars.com/threads/anoth...-latch.129329/
Old 01-14-2023, 08:50 AM
That's a nice clean install Markantioch, clean simple, the manual latch is trick. And best of all the 80's 10 speed cable is gone!
Old 01-14-2023, 08:54 AM
That looks like a lot of turkey carving being done. A simple bungee rope would look cleaner.
Mark
Old 01-14-2023, 09:04 AM
found a video
https://www.youtube.com/watch?v=QmOiWu2RFIc
Old 01-14-2023, 09:17 AM
That will also work but you'll need a 2-wire loom going from the body to the door to power it up. Mine uses 3 carriage bolts that keeps the mounting spots a their thickest.
Mark
