Like Tree6Likes
  • 2 Post By Sycraft
  • 1 Post By Alfa02
  • 2 Post By hinoonaz
  • 1 Post By Sycraft
Old 02-18-2023, 11:02 AM
Sycraft's Avatar
Cobra Make, Engine: ford 302
Default Sidepipes Classic Chambered
had a set of new sidepipes made locally and had ceramic coated too. used the Classic Chambered mufflers and had all new pipes done. Still have my original set as well if anything happens to these. When completed, I pulled the headers too and had them all Ceramic Coated locally. Used new Remflex gaskets on all connections and stage 8 locking header bolts as well. Sounds great sitting, now to get on the road soon, too cold right now.
EM-0785 and 74proii like this.
Old 02-18-2023, 12:19 PM
Alfa02's Avatar
Gold Star Contributor
I have a pair on my 347, love the sound, mellow (Tuned?) Tone I would say, Brent (EM-0785) has them on his 514 BBF, and they sound great on a Big Block as well, very well made. Here's hoping you like them as much Sycraft Cheers Tom.
EM-0785 likes this.
Old 02-19-2023, 10:25 AM
very nice
Old 02-20-2023, 06:36 AM
I replaced FFR original of 24 years with classic chambered muffler. Turned tip down 5 degrees . Sounds fantastic and is now the best sounding leaf blower!!!!
MaSnaka and Alfa02 like this.
Old 02-20-2023, 11:38 AM
MaSnaka's Avatar
Sycraft you may need to re tune your engine. I picked up 80HP when I switched over to the CC mufflers 2 1/2" on my 390fe. I was pretty shocked at how restrictive the CR pipes were.
Old 02-20-2023, 08:10 PM
Sycraft's Avatar
Neutral
True, but only a 302 already making pretty good hp for that displacement. If I can gain on 342 hp I will be happy, plus I was slightly rich before, so this may settle right in
Old 03-19-2023, 03:01 PM
Sycraft's Avatar
Went for a 40 degree test drive, could not stand it any longer. All I can say is that the sound is much deeper than the classic industries sidepipes and they sound fantastic. As far as power, its still too cold to really check, and I have not driven it in several months. but overall I'd say it makes the car feel stronger. Spinning through 1st and 2nd getting on the ramp is always a pleasure.
Old 03-20-2023, 07:08 AM
can you snap a picture of how you mounted it?
Good to hear you like it!
Old 03-20-2023, 01:01 PM
Cobra Make, Engine: Classic Roadsters Ford
Still in the building stages and need to buy a set of headers and side pipes. The motor I am putting in is a 351 Cleveland with 4V heads. Was looking at GasN touring, but they would have to build custom headers. Is there anything off the shelf that would work with my setup? I would be capable of making modifications to an suit, but need to have something to start with. Any suggestions would be welcome.
Old 03-20-2023, 08:04 PM
Sycraft's Avatar
I used my original set as a templet, my shop was reasonable, 900 for the pair plus coating.
Old 03-20-2023, 08:05 PM
Sycraft's Avatar
not sure, pics above?
Old 03-22-2023, 07:08 AM
have never seen any factory ones. I was wondering what the brackets off the pipes looked like to connect to the frame. the pic you posted cut them off. I imagine I'll be doing something different anyway
Old 03-25-2023, 08:03 AM
what part numbers did you use for your exhaust from Chambered?
Old 03-25-2023, 02:17 PM
Sycraft's Avatar
2528-COBRA-P
28" 2.5 inner with packing
Roylerumble likes this.
Old 03-28-2023, 06:59 PM
Cobra Make, Engine: Classic roadsters ll
Default Side pipes
Hi I was looking at the side pipes for the classic roadster.I have a question where did get them made.also who did the ceramic coating.I have a classic roadster ll I might be looking for some thanks
Old 03-28-2023, 07:54 PM
Chicagowil's Avatar
I got my original side pipes out today and took a couple of photos of the rear hanger design.
If you need measurements or a template, let me know.
I believe any powder coating shop should be able to finish your pipes after they are welded up.
Mine are chrome fro CR. I will put them on just to get the car runnong. But I plan to replace them with new muffles as described above, and have them powder coated like I did my headers.
Old 03-29-2023, 02:46 PM
cobra 53's Avatar
Cobra Make, Engine: NAF 289 Blue/White strips
Hello
Have for many years Classic Chambered Sidepippes on my NAF Cobra 302. Best sound and runs great. Also at high rews.
Regards from sunny Spain
Ricohttps://youtu.be/D-r0hgZJVEw
Rico, NAF 289
Old 03-29-2023, 03:15 PM
cobra 53's Avatar
Rico, NAF 289
Old 03-29-2023, 04:32 PM
Chicagowil's Avatar
Originally Posted by cobra 53 View Post
Hello
Rico
One of my wife's and I's favorite countries to vacation in!
Old 11-27-2024, 05:11 PM
Default Side pipes
Hi where did you get the side pipes made I might be looking for a set for my classic roadster ll.thanks
